(#441)
| Junior Member Posts: 16 Join Date: Jul 2009 | Quote:
(#442)
| Junior Member Posts: 13 Join Date: May 2009 Location: Canada | The audio fix works really well. I had it installed since yesterday and so far, it hasn't ran into any problems. Everything seems to be functioning well apart from the mute functionality when having the headphones plugged in. Other than that, its amazing! Heres my two cents on installing the audio drivers. So, if you've installed any audio kext(s) before like the VoodooHDA, you'll have to remove it first. You should be able to find those kext(s) under: \System\Library\Extensions Things to Download: - Kext Helper b7 - Vanilla AppleHDA (This is the stock leopard kext file) - LegacyAppleHDA - HDAEnabler - VerbHelper Steps: 1) Remove any installed audio kext(s) from previous installation(s) 2) Restart to make sure no audio devices are detected anymore (check if there are entries in the input and output tab from system preferences > sound) 3) Open up Kext Helper b7 4) Drag and Drop all the .kext files (AppleHDA, LegacyAppleHDA, HDAEnabler, VerbHelper) into the Kext Helper b7 5) Enter your admin password in the textbox and click "Easy Install" 6) Restart your mini This was what I did and it works on mine. I've attached a zip file with all the files you need as mentioned above. Hope it works on your dell mini! Just for reference (if it matters at all), I installed OSX using dellEFI 125a. Thanks to lnxneo and anguish for all the help! MacBook - Core Duo 2.0GHz - 2GB RAM - 250GB HD - OSX 10.4.11 MacBook Pro - Core 2 Duo 2.53GHz - 4GB RAM - 320GB HD - 9600M GT w/ 512MB - OSX 10.6.1 |
(#443)
| Super Moderator Posts: 1,203 Join Date: Apr 2009 Location: Detroit | http://www.mydellmini.com/forum/mac-...ing-audio.html <--- This is the right link. Not sure why the one referenced above didn't work, but this is the one from my first post in this thread. Triple Boot Guide - 10v RAM Upgrade Videos - mechdrew's OSX guides |
(#444)
(#445)
| Expert Member Posts: 692 Join Date: Mar 2009 | Since I have a mini9 I just sort of keep half an eye on these threads... Just 1 question and a half, I assume from what folks saying it works that the static after sleep issue is also fixed? So that the only thing that doesn't work right it being unable to mute headphones, but that muting the regular speakers does work? Mini2: Mini9, Black, 2G, 0.3 Webcam, Bluetooth, 32G RunCore, OS X/Win 7, internal PCI-e SHDC Reader Mini3: Mini10v. Black, 2G, Webcam, 640G HD, OS X 10.5.8/Win 7/Ubuntu [Hibernate w/NBI 0.8.3 RC4] Dropbox Referral |
(#446)
| Super Moderator Posts: 1,203 Join Date: Apr 2009 Location: Detroit | That's correct, although it looks like there may be a fix for the headphone mute issue as well. Triple Boot Guide - 10v RAM Upgrade Videos - mechdrew's OSX guides |
(#447)
| Member Posts: 99 Join Date: Mar 2009 Location: Fredericton, New Brunswick, Canada | | Dell Mini 10v | Obsidian Black | 1.6GHz | 2GB Kingston HyperX | 1.3MP | 160GB SATA HDD | Bluetooth | 802.11n | Windows 7 Ultimate | Eagles may soar, but weasels don't get sucked into jet engines. - Unknown Before Elvis, there was nothing. - John Lennon |
(#448)
| Junior Member Posts: 26 Join Date: Jun 2009 Location: Atlanta, GA | I had the voodooHDA installed. I removed voodooHDA, downloaded the corresponding files, and followed the instructions exactly....Everything is working great. Thanks so much. This is huge. I think I am just about 100% working (the internal mic was the last thing on my checklist). Quote:
(#449)
| Senior Member Posts: 105 Join Date: Jan 2009 Location: Los Angeles, CA | Quote:
Tried this method. Nothing. My speakers and muting of them work fine as they have since day one, but I still have no headphones and no internal mic. I'll keep watching. | |
(#450)
| Junior Member Posts: 1 Join Date: Aug 2009 | Working perfectly for me. Removed VoodooHDA, installed new Kexts, rebooted and everything was working. Things did seem very laggy however. Rebooted, and now everything is perfect again. Made a skype call and everything sounded perfect. Thanks! Quote:
« Thank you all
console error »
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-10v-mac-os-x-discussion/8694-mini-1011-mini-10v-os-x-info-updated-audio.html | ||||
| Mini 10v OS X UPDATED for AUDIO! - These guys... - Jan Ole Peek - FriendFeed | This thread | Refback | 10-03-2009 09:32 AM | |
| permafrown's Bookmarks on Delicious | This thread | Refback | 09-03-2009 07:38 AM | |
| Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums | This thread | Refback | 09-02-2009 10:06 PM | |
| toddje's Network on Delicious | This thread | Refback | 09-01-2009 02:50 PM | |
| ???????? : Macintosh | This thread | Refback | 08-29-2009 08:54 AM | |
| ???????? | This thread | Refback | 08-29-2009 02:05 AM | |
| Mac fans | This thread | Refback | 08-25-2009 09:14 PM | |
| The State of Hackintosh: Which Netbooks to Hack [Hackintosh] - Nibbet.com | This thread | Refback | 08-25-2009 01:59 PM | |
| 1:1 Moving at the Speed of Creativity | This thread | Refback | 08-24-2009 10:14 PM | |
| Dell Mini 10v | Austin Kim | This thread | Refback | 08-24-2009 08:01 PM | |
| Mini 1011 (Mini 10v) and OS X - Info - UPDATED for AUDIO!!!! | This thread | Refback | 08-24-2009 01:19 PM | |
| ???????? ????? - blog:N@TURE BRAIN | This thread | Refback | 08-24-2009 03:54 AM | |
| The State of Hackintosh: Which Netbooks to Hack [Hackintosh] | This thread | Refback | 08-21-2009 05:59 PM | |
| osx - Jochen Lillich on Diigo | This thread | Refback | 08-19-2009 06:53 PM | |
| The State of Hackintosh: Which Netbooks to Hack [Hackintosh] - Striker Techo Feeder (RSS) | This thread | Refback | 08-19-2009 12:51 AM | |
| Hcl - Muzzle.nl | This thread | Refback | 08-18-2009 05:48 PM | |
| dell | Eee PC - Blog - Part 2 | This thread | Refback | 08-13-2009 09:30 AM | |
| My Dell Mini 10V Netbook with Ubuntu is on the way Moving at the Speed of Creativity | This thread | Pingback | 08-12-2009 04:31 PM | |
| Jan Ole Peek - Comments | This thread | Refback | 08-11-2009 03:29 PM | |
| Mini 1011 (Mini 10v) and OS X - Info - UPDATED for AUDIO!!!! - Page 45 | This thread | Refback | 08-10-2009 05:35 PM | |
| Randomness lenovo s10-2 | This thread | Refback | 08-09-2009 01:01 AM | |
| Wikipedia | This thread | Refback | 08-08-2009 05:56 AM | |
| calmahomer's Bookmarks on Delicious | This thread | Refback | 08-07-2009 06:44 PM | |
| Updated Hackintosh Compatibility Chart -:: Malaysia Mobile Tech News ::- | This thread | Refback | 08-07-2009 10:18 AM | |
| livedoor ???? - ?????????????????????? | This thread | Refback | 08-06-2009 01:46 PM | |
| RSS fabriek os x | This thread | Refback | 08-06-2009 06:45 AM | |
| CHW Los mejores netbooks para instalar Mac OS X | This thread | Refback | 08-05-2009 08:44 AM | |
| ?????????????????????? : Gizmodo Japan????????????, ???????????? | This thread | Refback | 08-04-2009 12:20 PM | |
| Randomness Dell mini 10v | This thread | Refback | 08-01-2009 12:21 PM | |
| ???????? : MacBook mini | This thread | Refback | 07-31-2009 09:01 PM | |
| ciaconne's Bookmarks on Delicious | This thread | Refback | 07-31-2009 01:31 PM | |
| The State of Hackintosh: Which Netbooks to Hack [Hackintosh] | NewsCred, Quality Newspapers & Blogs | This thread | Refback | 07-31-2009 12:46 PM | |
| The State Of Hackintosh: Which Netbooks To Hack | Gizmodo Australia | This thread | Refback | 07-31-2009 12:41 AM | |
| Gizmodo - The State of Hackintosh: Which Netbooks to Hack | This thread | Refback | 07-30-2009 11:03 PM | |
| The State of Hackintosh: Which Netbooks to Hack - Mac os x netbook chart - Gizmodo | This thread | Refback | 07-30-2009 06:08 PM | |
| Untitled document | This thread | Refback | 07-30-2009 08:58 AM | |
| MacOSX86̖낤!24 | This thread | Refback | 07-29-2009 11:25 AM | |
| Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums | This thread | Refback | 07-28-2009 04:50 PM | |
| Hackintosh-Erfahrungsbericht zum Dell Mini 9 mit Mac OS X 10.5.7 [Update] - macboard.ch | This thread | Refback | 07-27-2009 08:44 AM | |
| Dell Mini 10v Hackintosh Underway | This thread | Refback | 07-25-2009 10:47 AM | |
| Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums | This thread | Refback | 07-24-2009 09:11 PM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums | This thread | Refback | 07-23-2009 09:07 PM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums | This thread | Refback | 07-23-2009 02:07 PM | |
| Netbook Review UK | Netbook and Mini-Laptop Reviews, Comparisons and News - Part 16 | This thread | Refback | 07-22-2009 11:40 PM | |
| j.lane's Bookmarks on Delicious | This thread | Refback | 07-21-2009 06:34 PM | |
| Dell Mini 10vで - blog:N@TURE BRAIN | This thread | Refback | 07-21-2009 12:09 AM | |
| Dell Mini9: Did I completely miss the boat on this? | This thread | Refback | 07-20-2009 04:55 PM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums | This thread | Refback | 07-19-2009 03:37 PM | |
| Dell Outlet Mini 10 and Mini 10v 15% off - New coupon code | This thread | Refback | 07-18-2009 12:29 AM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums | This thread | Refback | 07-17-2009 09:06 PM | |
| はてなブックマーク - caminoroad のブックマーク | This thread | Refback | 07-15-2009 04:02 PM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - SlickDeals.net Forums | This thread | Refback | 07-13-2009 08:32 PM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - UNDER $200 shipped! - SlickDeals.net Forums | This thread | Refback | 07-12-2009 03:38 AM | |
| Dell Inspiron Mini 10 (10v): Hackintosh - gdgt | This thread | Refback | 07-10-2009 03:57 PM | |
| MyDellMini | Site profile | BoardReader | This thread | Refback | 07-10-2009 01:02 PM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - UNDER $200 shipped! - SlickDeals.net Forums | This thread | Refback | 07-10-2009 12:25 PM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums | This thread | Refback | 07-10-2009 03:31 AM | |
| Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums | This thread | Refback | 07-10-2009 01:57 AM | |
| Dell Mini 10v now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums | This thread | Refback | 07-09-2009 09:01 PM | |
| Mini 1011 (Mini 10v) and OS X - Info - Page 11 - MyDellMini | This thread | Refback | 07-08-2009 04:28 PM | |
| DELL MINI10ΰװ10.5.6 - Mac OS X -[Leopardۺ] - Mac OS X For PC (X86) - Զ̳ - ǵϵͳ̳|Windows 7,Windows Vista,Windows XP,Mac OS X | This thread | Refback | 07-08-2009 07:47 AM | |
| os x Diet Recipes Free | This thread | Refback | 07-07-2009 11:43 PM | |
| Foros Cantv.net: NUEVA MINI SIRAGON ATHOM 1.6 GHZ | This thread | Refback | 07-05-2009 01:34 AM | |
| .mac.ro - Your site for news around planet .mac - Immer die aktuellsten Nachrichten und Meldungen. | This thread | Refback | 07-02-2009 08:59 AM | |
| Dell Mini 10v now available in Dell Outlet Home! - SlickDeals.net Forums | This thread | Refback | 06-30-2009 01:40 PM | |
| Dell Mini 10v now available in Dell Outlet Home! - SlickDeals.net Forums | This thread | Refback | 06-30-2009 03:23 AM | |
| whalespine.org | This thread | Refback | 06-29-2009 10:44 PM | |
| Mini 1011 (Mini 10v) and OS X - Info - MyDellMini - mtakeshi - FriendFeed | This thread | Refback | 06-28-2009 12:26 PM | |
| ڹΥ֥ : Boot123 | This thread | Refback | 06-28-2009 04:53 AM | |
| Mini 1011 (Mini 10v) and OS X - Info - MyDellMini | This thread | Refback | 06-27-2009 11:27 PM | |
| Topic: hackintosh - MyBlogLog | This thread | Refback | 06-26-2009 11:25 PM | |
| EEE PC - The unofficial blog about Asus Eee PC - Part 9 | This thread | Refback | 06-24-2009 10:04 AM | |
| Jason Fitzpatrick's Messages | This thread | Refback | 06-23-2009 01:03 PM | |
| Jan Ole Peek - FriendFeed | This thread | Refback | 06-23-2009 05:43 AM | |
| Competitor | Eee PC - Blog - Part 3 | This thread | Refback | 06-22-2009 08:48 PM | |
| DELL MINI10ΰװ10.5.6 - Mac OS X -[Leopardۺ] - Mac OS X For PC (X86) - Զ̳ - ǵϵͳ̳ Windows 7,Windows Vista,Windows XP,Mac OS X | This thread | Refback | 06-21-2009 03:08 AM | |
| MacOSX86̖낤!24 | This thread | Refback | 06-21-2009 02:53 AM | |
| studioda blog : DELL Mini10 - MacOS DVD 起動せず... | This thread | Refback | 06-17-2009 10:58 AM | |
| alexander.platz's Bookmarks on Delicious | This thread | Refback | 06-17-2009 08:00 AM | |
| ڹΥ֥ | This thread | Refback | 06-12-2009 10:59 AM | |
| ڹΥ֥ : 2009ǯ06 | This thread | Refback | 06-12-2009 08:12 AM | |
| johaneje's Bookmarks on Delicious | This thread | Refback | 06-12-2009 07:19 AM | |
| lostgweilo's Bookmarks on Delicious | This thread | Refback | 06-12-2009 04:35 AM | |
| douglasgraves's dell Bookmarks on Delicious | This thread | Refback | 06-11-2009 04:21 AM | |
| EEE PC - The unofficial blog about Asus Eee PC - Part 4 | This thread | Refback | 06-10-2009 05:21 PM | |
| Liliputing Compact Computing | This thread | Refback | 06-10-2009 03:52 PM | |
| os x | This thread | Refback | 06-09-2009 10:41 PM | |
| Wikipedia | This thread | Refback | 06-08-2009 03:22 AM | |
| jevaun's Bookmarks on Delicious | This thread | Refback | 06-07-2009 02:43 AM | |
| dotMb -Web for Macbook Users and future Macbook Users- | This thread | Refback | 06-06-2009 02:57 AM | |
| ڹΥ֥ : Macintosh | This thread | Refback | 06-05-2009 04:21 PM | |
| Liliputing Compact Computing | This thread | Refback | 06-05-2009 06:50 AM | |
| Dell | Eee PC - Blog | This thread | Refback | 06-04-2009 10:59 PM | |
| RedFlagDeals.com Forums - Comp Dell mini 10v starting $329 | This thread | Refback | 06-04-2009 04:31 AM | |
| mobileMacs Blog Archive MM028 am nchsten Mittwoch | This thread | Refback | 06-03-2009 02:06 PM | |
| 10-inch | Eee PC - Blog | This thread | Refback | 06-03-2009 10:25 AM | |
| ڹΥ֥ : MacBook mini | This thread | Refback | 06-03-2009 05:31 AM | |
| ڹΥ֥ : Dell Mini 10ǤMacOSX Leopard ưԤ줿褦Ǥ | This thread | Refback | 06-03-2009 12:39 AM | |
| Accelerate Your Mac News Archive for Monday June 1, 2009 | This thread | Refback | 06-02-2009 08:41 PM | |
| Accelerate Your Macintosh! News Page - 6/2/09 | This thread | Refback | 06-02-2009 07:15 PM | |
| Mac OS X Netbook Compatibility Chart (Updated June 2009: Dell Mini 10v) | Boing Boing Gadgets | This thread | Refback | 06-02-2009 03:22 PM | |
| [Comp] Dell mini 10v starting $329 - Page 4 - RedFlagDeals.com Forums | This thread | Refback | 06-02-2009 03:01 PM | |
| Liliputing Compact Computing | This thread | Refback | 06-02-2009 02:53 PM | |
| Dell Mini 10v | Eee PC - Blog | This thread | Refback | 06-01-2009 11:18 PM | |
| dell inspiron mini 10v | This thread | Refback | 06-01-2009 03:55 PM | |
| Dell Mini 10v: the cheapest Mac ever? - mirror.co.uk | This thread | Refback | 06-01-2009 02:24 PM | |
| Dell Inspiron Mini 10v loaded with Mac OS X | GadgetMix.com!::.. | This thread | Refback | 06-01-2009 01:36 PM | |
| Dell Mini 10v: the cheapest Mac ever? | ElectricPig.co.uk | This thread | Refback | 06-01-2009 01:34 PM | |
| Innocents & Mortals | This thread | Refback | 06-01-2009 08:53 AM | |
| Dell Inspiron Mini 10v, Hackintosh edition with OSX | Netbook Review UK - Netbook Reviews, Compare Netbooks and Netbook News | This thread | Pingback | 06-01-2009 07:51 AM | |
| Dell Mini 10v Running OS X | Eee PC - Blog | This thread | Pingback | 05-31-2009 11:08 PM | |
| hackintosh | This thread | Refback | 05-31-2009 06:55 PM | |
| Dell Inspiron Mini 10v unboxed, loaded with OS X | This thread | Refback | 05-31-2009 04:18 PM | |
| Liliputing Compact Computing | This thread | Refback | 05-31-2009 04:07 PM | |
| 11.6 Acer Aspire One AO751h US Preorders Up - Portable Monkey | This thread | Refback | 05-31-2009 12:53 PM | |
| Explore tags on Delicious | This thread | Refback | 05-31-2009 05:06 AM | |
| Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums | This thread | Refback | 05-30-2009 10:47 PM | |
| fscklog: Hackintosh-Erfahrungsbericht zum Dell Mini 9 mit Mac OS X 10.5.7 [Update] | This thread | Refback | 05-30-2009 03:59 PM | |
| Dell Phasing Out Dell Mini 12 in July? - Portable Monkey | This thread | Refback | 05-30-2009 10:05 AM | |
| Dell Mini 10v Hackintosh Underway - Portable Monkey | This thread | Refback | 05-30-2009 09:27 AM | |
| Portable Monkey | This thread | Refback | 05-30-2009 09:10 AM | |
