  (#431) Old
Default bt no joy - 07-28-2009, 10:09 PM
Originally Posted by peekj View Post
Huh, strange, I have the exact same bluetooth adapter and it doesn't do a thing for me. Nothing, no entry in the menu bar, no entry in the system preferences.
maybe a sanity check is in order. goto system profiler in utilities and look in hardware. click on bluetooth. if you have a connected module that is working, you should see a slew of info. if you dont, crack that case open and make sure that your connector cable is put in all the way and the little locking bars on each side are engaged so the cable doesnt come out.
  (#432) Old
peekj's Avatar
Default 07-28-2009, 10:13 PM
Well it's a usb adapter, not built-in bluetooth, so no need to crack the case open... the adapter has a small blue light that does come on, so it's getting power, but it's not showing up anywhere.
  (#433) Old
anguish's Avatar
Default 07-30-2009, 12:37 PM
Gang, made an update on the audio piece.
  (#434) Old
anguish's Avatar
Default 07-31-2009, 01:54 AM
Gang,
Over the next few days (probably early next week), I hope to have my first post rewritten. Anything that's not in there that you think needs to be in there, let me know please.
Thanks!
  (#435) Old
Default 07-31-2009, 12:38 PM
just in time for my first install.. got the 10v on Monday. Thanks so much for the Audio Update.. Seems to be a cleaner update from the original Voodoo solution.
  (#436) Old
Default 07-31-2009, 03:22 PM
anguish- could you elaborate a little on these steps?
1) Go download Kext Helper b7 from http://cheetha.net.. You'll need it to make life easier.
2) Goto this link: Building 100% Vanilla on 10v (starting with fully working Audio)
3) Launch Kext Helper b7, and then drag and drop the kext you just nabbed the Kext Helper b7 app. Easy Install, reboot, and you should be good.
I don't take any credit for the above fix, other than by doing some searching via Google, and for the most recent stuff, the rocking work of lnxneo (sorry if I misspelled the name).
it appears this user had made it seem like a drop and drap job. The kext is not named so i am unsure which to use from http://www.mydellmini.com/forum/mac-...ing-audio.html
  (#437) Old
anguish's Avatar
Default 07-31-2009, 03:31 PM
In the case of several of us, there were a total of four kexts posted in that thread. It took the installation of all for kexts using kext helper to get it to work. I plan on elaborating more when I rewrite that entire first post.
  (#438) Old
Default 07-31-2009, 05:34 PM
Thank you!! very helpful as usual!
  (#439) Old
Default 07-31-2009, 05:42 PM
a rewritten instruction that covers everything would be nice. i'm a noob at this and while the bootmaker/netbook app was fantastic, it did take some searching to figure out how to use them.
i dropped all four ktext files (applehda, legacy apple hda, hdaenabler, verbhelper) and the microphone still doesn't work. i had a fresh install and used the netbookinstaller after upgrading to 10.5.7. wondering what went wrong.
  (#440) Old
Default Broken link - 07-31-2009, 09:50 PM
"Goto this link: Building 100% Vanilla on 10v (starting with fully working Audio)
The link doesn't work........
-- Dell Mini 10v with 1 Gig RAM, 160 Gig HD, Running Dual-Boot - Mac OS-X 10.6.4 and Windows 7 Home Premium
Posted By For Type Date
