  (#161) Old
MacG's Avatar
Smile 10v-Installed 2GB, Now Leopard - 06-06-2009, 02:46 AM
EDITED: I posted the entire 2GB memory upgrade and OS X install in one guide. http://www.mydellmini.com/forum/dell-mini-10-guides/9205-mac-users-view-hackintoshing-mini-10v.html#post75351
Here's what I did today.
1. Picked up my 10v from my shipping center at work.
2. Stopped by Microcenter to get a $17.99 2GB DDR2 667 SO-DIMM
3. Picked up a 8GB USB Flash Drive
4. Used the Dell Mini 10v service manual to get to the system board.
5. Used the lid from the 10v packaging as a screw holder. Labeled each "pit/indention"...made it easy to remember what to put back.
Memory Installation.
1. Removed Battery
2. Removed Wifi Mini Card
3. Removed Keyboard
4. Removed Palmrest
5. Removed Palmrest holder
6. Pulled 2 screws from system board and flipped up the system board to get to the DIMM slot.
7. Follow the directions in the system manual very closely. When it says pull from the left and right sides with your fingers, take the hint.
8. Put everything back together in reverse order.
The whole memory upgrade took 30 mins. I never opened a Dell before, but it's much easier than a PowerBook/iBook G4 hard drive upgrade!
Back to Mac OS X install:
1. No need to Press F2 to change firmware settings, the 10v was all ready set with the correct settings for Mac OS X install.
2. Restored 10.5.0 onto the 8GB Flash drive
3. Removed some optional/developer installs to fit all the Dell Mini hackintosh files and 10.5.7 upgrade
4. Ran DellEFI Bootloader 3.3 (for 2GB models, use 3.2 for 1GB)
5. Pressed F12 to boot off USB Flash Drive
6. Formatted the drives with 2 partitions, 20 GB for Snow Leopard (that's tomorrow) and 91GB for Leopard.
7. Started install. No issues with tabbing to buttons, everything was visible.
**EDITS**
8. Made sure I had named the partition correctly (OSXMINI9). That fixed my spinning indicator issue where the OS would not boot.
9. I used DellEFI 1.2a5 (Worked surprisingly well), no issues since I turned a few things off first (turned off Restore the 10.5.5 keyboard, Remote CD, Disable Hibernate) Turned on: Install Chameleon, Install Dell Mini 9 Drivers, Hide DellEFI files, Generate a system specific dsdt.aml file and Fix bluetooth.
10. Booted back into Mac OS X 10.5.0, upgraded to 10.5.7 from Combo installer.
11. Ran DellEFI 1.2a5 again, same items turned on and off (see #9).
12. Reboot-Turned off Legacy USB support so I can wake from sleep and plug in a USB Mouse.
13. Updated 10v BIOS to A02 (ok, I'm pushing my luck , Grabbed another 1GB USB flash drive, Made it bootable with HP USB boot drive
14. BIOS upgrade went well, no problems.
Fix the WIFI issue:
1. Open Network in the System Preferences
2. Remove everything except Ethernet 2
3. Reboot
4. Open Network again
5. Add AirPort
Now the Menu Item signal strength works, WiFi stays on after reboot and it feels more like a Mac.
Observations on Day 2:
1. Love the feel of the Mini 10v, keyboard is great and I'm already naturally typing. Six-cell battery is getting 5-6 hours of use, recharge in a couple of hours. Battery feels like it's not solidly in place, moves a small amount, but I use it for a handle and keyboard tilt stand.
2. Hate the trackpad. I have to use two hands/two fingers to click on items. I wish they used Apple's no-button trackpad innovation - turn off the area at the bottom of trackpad so it acts like a button.
3. Resolution is fine, I use Terminal and type "defaults write -g AppleDisplayScaleFactor 0.8" (without quotes) to get the windows to automatically resize if I'm having issues viewing anything. I set it back since it makes some of the menu items wonky ("defaults write -g AppleDisplayScaleFactor 1.0")
4. Trying to install Snow Leopard 10A354 later today, it's going to take 2 hours
5. Installed DropBox (2GB free storage)
6. Bluetooth A2DP works great and I can listen to my music on my $25 Kensington bluetooth headset. Make sure you select the Bluetooth menu item, scroll to your headset and choose Use Headphones from the submenu instead of headset. Headset is for single-ear, mono bluetooth devices.
Will be posting my full 2GB install, OS X 10.5.7 install and BIOS upgrade walkthrough after the kids go to sleep tonight. With pictures.
thanks...Lee
Dell Mini 10v, 2GB, 120GB, 6-Cell, BT, 802.11n | Mac OS X 10.6.1 - 10v Hackintosh Guide - Get Dropbox for Mac OS X 2GB Free
  (#162) Old
Default 06-06-2009, 03:42 AM
1. Removed Battery
3. Removed Keyboard
4. Removed Palmrest
8. I'm on the Install Failed screen, now will continue with Single-USB Install guide.
thanks...Lee
Hey Lee where did you see the manual for the ram upgrade?
  (#163) Old
Default 06-06-2009, 04:53 AM
Disregard found it here
Documentation
The ram upgrade is not for everyone. What is supposed to pop up like the palm rest and system board does come up but will scare you.
There are way too many screws and the ram is under the system board. EVERYTHING comes out. Make sure you remember where each screw goes they are many different sizes and lengths. It took me 30 minutes but I have done this on a few laptops before.
  (#164) Old
MacG's Avatar
Default 06-06-2009, 06:59 AM
I've got pictures and links. Just need to write it up (I'll do this sometime this weekend). After doing one, I could probably shave 10 mins off the install. Most of the fear came from fitted plastic pieces with tabs. Small computer, small tabs. Also, had to memorize the order I did things, so I wouldn't forget to replug USB or power
thanks...Lee
  (#165) Old
minibaby's Avatar
Default 06-06-2009, 07:19 AM
Received 10v today.
Took it apart and replaced its RAM with a new 2GB. Managed to do it without breaking any parts.
Replaced the 120HDD with a Runcore 64GB SATA SSD (with OS X 10.5.6 on it already.)
Pretty much everything except for sound works (I haven't had time to check everything)
Ran DellEFI 1.1 and rebooted.
Updated it to 10.5.7.
Mini 10v | 2GB Transcend RAM | Runcore 64GB Pro IV | BIOS A06 | OS X 10.6.8
  (#166) Old
MacG's Avatar
Default 06-06-2009, 06:22 PM
I cant get 0S X to load because the resolution is screwed and I cant get to the enter button its off the screen. Any ideas? Will another monitor work? Can I change the resolution in terminal then finish the install?
I can get the HD reformatted but thats as far as I can go.
thanks
Hey Mario,
I installed OS X 4 times (trying different configs) and not once, I had an issue with the resolution cutting off a window. Is it possible you're in safe mode when installing? You should have enough pixels for an OS X install (I'm installing from retail 10.5.0.)
thanks...
  (#167) Old
Default 06-06-2009, 08:18 PM
Hi all.
Were you able to use ichat video conference ? I am not able to use the microphone, both internal, or by using an external microphone.
Arnaud
  (#168) Old
Default 06-06-2009, 11:57 PM
Originally Posted by nounours_2099 View Post
Hi all.
Arnaud
I've yet to be able to use the microphone either. It shows up in the system preferences, but is not active. Doing a completely fresh install now ....
  (#169) Old
MacG's Avatar
Default 06-07-2009, 12:35 AM
Hi all.
Arnaud
It seams the RealTek drivers don't support audio in from the 10v hardware. I'll try Bluetooth headset audio.
Update: Bluetooth headset mode works with OS X audio input. It puts changes from A2DP back to mono mode, with all the nice hissing of a 1970's AM radio. But the microphone works.
  (#170) Old
Default 06-07-2009, 02:02 AM
when I try to iChat, the recipient receives incessant clicking from the 10v, no audio. (the camera works great though). hopefully this will get worked out by the wizards here, otherwise I may go back to a mini 9 ...
Posted By For Type Date
Mini 10v OS X UPDATED for AUDIO! - These guys... - Jan Ole Peek - FriendFeed This thread Refback 10-03-2009 09:32 AM
permafrown's Bookmarks on Delicious This thread Refback 09-03-2009 07:38 AM
Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 09-02-2009 10:06 PM
toddje's Network on Delicious This thread Refback 09-01-2009 02:50 PM
???????? : Macintosh This thread Refback 08-29-2009 08:54 AM
???????? This thread Refback 08-29-2009 02:05 AM
Mac fans This thread Refback 08-25-2009 09:14 PM
The State of Hackintosh: Which Netbooks to Hack [Hackintosh] - Nibbet.com This thread Refback 08-25-2009 01:59 PM
1:1 Moving at the Speed of Creativity This thread Refback 08-24-2009 10:14 PM
Dell Mini 10v | Austin Kim This thread Refback 08-24-2009 08:01 PM
Mini 1011 (Mini 10v) and OS X - Info - UPDATED for AUDIO!!!! This thread Refback 08-24-2009 01:19 PM
???????? ????? - blog:N@TURE BRAIN This thread Refback 08-24-2009 03:54 AM
The State of Hackintosh: Which Netbooks to Hack [Hackintosh] This thread Refback 08-21-2009 05:59 PM
osx - Jochen Lillich on Diigo This thread Refback 08-19-2009 06:53 PM
The State of Hackintosh: Which Netbooks to Hack [Hackintosh] - Striker Techo Feeder (RSS) This thread Refback 08-19-2009 12:51 AM
Hcl - Muzzle.nl This thread Refback 08-18-2009 05:48 PM
dell | Eee PC - Blog - Part 2 This thread Refback 08-13-2009 09:30 AM
My Dell Mini 10V Netbook with Ubuntu is on the way Moving at the Speed of Creativity This thread Pingback 08-12-2009 04:31 PM
Jan Ole Peek - Comments This thread Refback 08-11-2009 03:29 PM
Mini 1011 (Mini 10v) and OS X - Info - UPDATED for AUDIO!!!! - Page 45 This thread Refback 08-10-2009 05:35 PM
Randomness lenovo s10-2 This thread Refback 08-09-2009 01:01 AM
Wikipedia This thread Refback 08-08-2009 05:56 AM
calmahomer's Bookmarks on Delicious This thread Refback 08-07-2009 06:44 PM
Updated Hackintosh Compatibility Chart -:: Malaysia Mobile Tech News ::- This thread Refback 08-07-2009 10:18 AM
livedoor ???? - ?????????????????????? This thread Refback 08-06-2009 01:46 PM
RSS fabriek os x This thread Refback 08-06-2009 06:45 AM
CHW Los mejores netbooks para instalar Mac OS X This thread Refback 08-05-2009 08:44 AM
?????????????????????? : Gizmodo Japan????????????, ???????????? This thread Refback 08-04-2009 12:20 PM
Randomness Dell mini 10v This thread Refback 08-01-2009 12:21 PM
???????? : MacBook mini This thread Refback 07-31-2009 09:01 PM
ciaconne's Bookmarks on Delicious This thread Refback 07-31-2009 01:31 PM
The State of Hackintosh: Which Netbooks to Hack [Hackintosh] | NewsCred, Quality Newspapers & Blogs This thread Refback 07-31-2009 12:46 PM
The State Of Hackintosh: Which Netbooks To Hack | Gizmodo Australia This thread Refback 07-31-2009 12:41 AM
Gizmodo - The State of Hackintosh: Which Netbooks to Hack This thread Refback 07-30-2009 11:03 PM
The State of Hackintosh: Which Netbooks to Hack - Mac os x netbook chart - Gizmodo This thread Refback 07-30-2009 06:08 PM
Untitled document This thread Refback 07-30-2009 08:58 AM
MacOSX86̖낤!24 This thread Refback 07-29-2009 11:25 AM
Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-28-2009 04:50 PM
Hackintosh-Erfahrungsbericht zum Dell Mini 9 mit Mac OS X 10.5.7 [Update] - macboard.ch This thread Refback 07-27-2009 08:44 AM
Dell Mini 10v Hackintosh Underway This thread Refback 07-25-2009 10:47 AM
Dell Mini 10 and 10v netbooks now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-24-2009 09:11 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-23-2009 09:07 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code via e-mail UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-23-2009 02:07 PM
Netbook Review UK | Netbook and Mini-Laptop Reviews, Comparisons and News - Part 16 This thread Refback 07-22-2009 11:40 PM
j.lane's Bookmarks on Delicious This thread Refback 07-21-2009 06:34 PM
Dell Mini 10vで - blog:N@TURE BRAIN This thread Refback 07-21-2009 12:09 AM
Dell Mini9: Did I completely miss the boat on this? This thread Refback 07-20-2009 04:55 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-19-2009 03:37 PM
Dell Outlet Mini 10 and Mini 10v 15% off - New coupon code This thread Refback 07-18-2009 12:29 AM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% off coupon code UNDER 200 SHIPPED! - SlickDeals.net Forums This thread Refback 07-17-2009 09:06 PM
はてなブックマーク - caminoroad のブックマーク This thread Refback 07-15-2009 04:02 PM
Dell Mini 10v netbook now available in Dell Outlet Home - SlickDeals.net Forums This thread Refback 07-13-2009 08:32 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - UNDER $200 shipped! - SlickDeals.net Forums This thread Refback 07-12-2009 03:38 AM
Dell Inspiron Mini 10 (10v): Hackintosh - gdgt This thread Refback 07-10-2009 03:57 PM
MyDellMini | Site profile | BoardReader This thread Refback 07-10-2009 01:02 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - UNDER $200 shipped! - SlickDeals.net Forums This thread Refback 07-10-2009 12:25 PM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums This thread Refback 07-10-2009 03:31 AM
Dell Mini 10v netbook now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums This thread Refback 07-10-2009 01:57 AM
Dell Mini 10v now available in Dell Outlet Home - 15% Coupon Code - SlickDeals.net Forums This thread Refback 07-09-2009 09:01 PM
Mini 1011 (Mini 10v) and OS X - Info - Page 11 - MyDellMini This thread Refback 07-08-2009 04:28 PM
DELL MINI10ΰװ10.5.6 - Mac OS X -[Leopardۺ] - Mac OS X For PC (X86) - Զ̳ - ǵϵͳ̳|Windows 7,Windows Vista,Windows XP,Mac OS X This thread Refback 07-08-2009 07:47 AM
os x Diet Recipes Free This thread Refback 07-07-2009 11:43 PM
Foros Cantv.net: NUEVA MINI SIRAGON ATHOM 1.6 GHZ This thread Refback 07-05-2009 01:34 AM
.mac.ro - Your site for news around planet .mac - Immer die aktuellsten Nachrichten und Meldungen. This thread Refback 07-02-2009 08:59 AM
Dell Mini 10v now available in Dell Outlet Home! - SlickDeals.net Forums This thread Refback 06-30-2009 01:40 PM
Dell Mini 10v now available in Dell Outlet Home! - SlickDeals.net Forums This thread Refback 06-30-2009 03:23 AM
whalespine.org This thread Refback 06-29-2009 10:44 PM
Mini 1011 (Mini 10v) and OS X - Info - MyDellMini - mtakeshi - FriendFeed This thread Refback 06-28-2009 12:26 PM
ڹΥ֥ : Boot123 This thread Refback 06-28-2009 04:53 AM
Mini 1011 (Mini 10v) and OS X - Info - MyDellMini This thread Refback 06-27-2009 11:27 PM
Topic: hackintosh - MyBlogLog This thread Refback 06-26-2009 11:25 PM
EEE PC - The unofficial blog about Asus Eee PC - Part 9 This thread Refback 06-24-2009 10:04 AM
Jason Fitzpatrick's Messages This thread Refback 06-23-2009 01:03 PM
Jan Ole Peek - FriendFeed This thread Refback 06-23-2009 05:43 AM
Competitor | Eee PC - Blog - Part 3 This thread Refback 06-22-2009 08:48 PM
DELL MINI10ΰװ10.5.6 - Mac OS X -[Leopardۺ] - Mac OS X For PC (X86) - Զ̳ - ǵϵͳ̳ Windows 7,Windows Vista,Windows XP,Mac OS X This thread Refback 06-21-2009 03:08 AM
MacOSX86̖낤!24 This thread Refback 06-21-2009 02:53 AM
studioda blog : DELL Mini10 - MacOS DVD 起動せず... This thread Refback 06-17-2009 10:58 AM
alexander.platz's Bookmarks on Delicious This thread Refback 06-17-2009 08:00 AM
ڹΥ֥ This thread Refback 06-12-2009 10:59 AM
ڹΥ֥ : 2009ǯ06 This thread Refback 06-12-2009 08:12 AM
johaneje's Bookmarks on Delicious This thread Refback 06-12-2009 07:19 AM
lostgweilo's Bookmarks on Delicious This thread Refback 06-12-2009 04:35 AM
douglasgraves's dell Bookmarks on Delicious This thread Refback 06-11-2009 04:21 AM
EEE PC - The unofficial blog about Asus Eee PC - Part 4 This thread Refback 06-10-2009 05:21 PM
Liliputing Compact Computing This thread Refback 06-10-2009 03:52 PM
os x This thread Refback 06-09-2009 10:41 PM
Wikipedia This thread Refback 06-08-2009 03:22 AM
jevaun's Bookmarks on Delicious This thread Refback 06-07-2009 02:43 AM
dotMb -Web for Macbook Users and future Macbook Users- This thread Refback 06-06-2009 02:57 AM
ڹΥ֥ : Macintosh This thread Refback 06-05-2009 04:21 PM
Liliputing Compact Computing This thread Refback 06-05-2009 06:50 AM
Dell | Eee PC - Blog This thread Refback 06-04-2009 10:59 PM
RedFlagDeals.com Forums - Comp Dell mini 10v starting $329 This thread Refback 06-04-2009 04:31 AM
mobileMacs Blog Archive MM028 am nchsten Mittwoch This thread Refback 06-03-2009 02:06 PM
10-inch | Eee PC - Blog This thread Refback 06-03-2009 10:25 AM
ڹΥ֥ : MacBook mini This thread Refback 06-03-2009 05:31 AM
ڹΥ֥ : Dell Mini 10ǤMacOSX Leopard ưԤ줿褦Ǥ This thread Refback 06-03-2009 12:39 AM
Accelerate Your Mac News Archive for Monday June 1, 2009 This thread Refback 06-02-2009 08:41 PM
Accelerate Your Macintosh! News Page - 6/2/09 This thread Refback 06-02-2009 07:15 PM
Mac OS X Netbook Compatibility Chart (Updated June 2009: Dell Mini 10v) | Boing Boing Gadgets This thread Refback 06-02-2009 03:22 PM
[Comp] Dell mini 10v starting $329 - Page 4 - RedFlagDeals.com Forums This thread Refback 06-02-2009 03:01 PM
Liliputing Compact Computing This thread Refback 06-02-2009 02:53 PM
Dell Mini 10v | Eee PC - Blog This thread Refback 06-01-2009 11:18 PM
dell inspiron mini 10v This thread Refback 06-01-2009 03:55 PM
Dell Mini 10v: the cheapest Mac ever? - mirror.co.uk This thread Refback 06-01-2009 02:24 PM
Dell Inspiron Mini 10v loaded with Mac OS X | GadgetMix.com!::.. This thread Refback 06-01-2009 01:36 PM
Dell Mini 10v: the cheapest Mac ever? | ElectricPig.co.uk This thread Refback 06-01-2009 01:34 PM
Innocents & Mortals This thread Refback 06-01-2009 08:53 AM
Dell Inspiron Mini 10v, Hackintosh edition with OSX | Netbook Review UK - Netbook Reviews, Compare Netbooks and Netbook News This thread Pingback 06-01-2009 07:51 AM
Dell Mini 10v Running OS X | Eee PC - Blog This thread Pingback 05-31-2009 11:08 PM
hackintosh This thread Refback 05-31-2009 06:55 PM
Dell Inspiron Mini 10v unboxed, loaded with OS X This thread Refback 05-31-2009 04:18 PM
Liliputing Compact Computing This thread Refback 05-31-2009 04:07 PM
11.6 Acer Aspire One AO751h US Preorders Up - Portable Monkey This thread Refback 05-31-2009 12:53 PM
Explore tags on Delicious This thread Refback 05-31-2009 05:06 AM
Dell mini 9 OSX How-to & Discussion: You got Apple in my Dell - The Something Awful Forums This thread Refback 05-30-2009 10:47 PM
fscklog: Hackintosh-Erfahrungsbericht zum Dell Mini 9 mit Mac OS X 10.5.7 [Update] This thread Refback 05-30-2009 03:59 PM
Dell Phasing Out Dell Mini 12 in July? - Portable Monkey This thread Refback 05-30-2009 10:05 AM
Dell Mini 10v Hackintosh Underway - Portable Monkey This thread Refback 05-30-2009 09:27 AM
Portable Monkey This thread Refback 05-30-2009 09:10 AM
