  (#121) Old
jeffburg's Avatar
Default 06-03-2009, 04:50 AM
Everyone should send a tweet to the dell_mini team at Dell Mini Team (Dell_Mini) on Twitter
I just send this message
Code:
@Dell_Mini Look how much trouble we are having with the low screen resolution on the 10v. Get the option for an HD screen. http://is.gd/MQ54
Hopefully if enough people say something they will say something back
-Jeff
  (#122) Old
Default 06-03-2009, 06:33 AM
I got my 10v today. While those audio drivers do "work", the headphone jack doesn't work at all. Can't even manually switch to the headphone jack. Looks like we're going to have to tag team the sound drivers again. I wonder if km9 still hangs around these forums, he's the one that did it last time.
The keyboard on the 10 is soooo much better than the 9. The screen resolution sucks. The install was exceptionally frustrating, trying to guess how many times to hit the tab key before hitting the space bar or enter. We need a Mini10v install guide that covers the number of times to hit tab and such. Uggg! They really need to offer the higher res screen as an option. Other than that, the install went without a hitch.*The touchpad drove me nuts until I installed meklort's drivers. I think he may need to customize them a bit for this machine, seems like the scroll isn't all the way to the right anymore, it's about a centimeter in from the edge. And it's bit nice to numb down the area near the "buttons", I just turned down the sensitivity on the whole pad for the time being.
I think that covers everything.. Oh yeah, zero issues with wifi, works like a champ for me. I used DellEFi 1.1, I still hate 1.2..
  (#123) Old
Default 06-03-2009, 10:47 AM
Hows the heat on this machine guys ? For those who have gotten it.
Comparing to the mini 9 w/ runcore.
i had it and it does heat up after about an hour.
  (#124) Old
Default 06-03-2009, 03:04 PM
Please could someone just answer two quick questions for me relating to OSX on the 10V with the 8GB SSD -
1) Does sleep work (And wake up of course) when you close/open the lid
2) Does wired ethernet work.
I might get one of these anyway to run Jolicloud on when it's released but OSX would be a big bonus as it's a lot lighter than my Macbook.
  (#125) Old
Default 06-03-2009, 03:09 PM
I don't know that anyone purchased the 10v w/ the 8GB SSD. I know a couple people got the 120GB drive and swapped in an OCZ Vertex.
I've got the 120GB drive running, and sleep and ethernet work fine.
Dunno how an SSD would change that.
OSX (10.5.7) - 10v - 1GB (for now)
I'm not even supposed to be here today.
  (#126) Old
Default 06-03-2009, 03:14 PM
Thanks Dante, I'm not sure about the USA but here in the UK the low-spec 10V comes with Ubuntu and the 8GB SSD, the next model up ($75 or so increase) comes with XP and a 160GB SATA drive.
I could of course get the cheaper one and swap out the SSD myself as for £50 I could get a lot bigger than 160GB (And M$ wouldn't get any money for the XP license)
  (#127) Old
meklort's Avatar
Default 06-03-2009, 03:58 PM
Could someone using the touchpad drivers open the console and search for ApplePS2Trackpad. There, could you tell me what version of the synaptic touchpad it is using and also if it says multi finger detection is supported or not.
Another thing. I noticed in the kextcache dump that it didn't have IOSDHCIBlockDevice.kext (the mini 9 sdhc driver) loaded. Could someone check to see if it's a usb device or if you actually need that driver. If it is a usb device, you should be able to install os x to it... (that and it's one less driver to install).
  (#128) Old
anguish's Avatar
Default 06-03-2009, 04:17 PM
Figures meklort, you ask and I'm in W7. Rebooting, will post my results. I'm only using whatever driver may have been installed with DellEFI 1.1.
  (#129) Old
anguish's Avatar
Default 06-03-2009, 04:25 PM
I'm still looking. Don't see anything in the Console. Still looking though.
Also, on the latter part, what's the easiest way to check that? I might not be able to do anything with that until after I get back from vacation.
  (#130) Old
anguish's Avatar
Default 06-03-2009, 04:29 PM
Okay, here's what I found for the trackpad:
Code:
May 29 07:32:19 localhost kernel[0]: ApplePS2Trackpad: Synaptics TouchPad v7.4
Posted By For Type Date
