Default Disco Lights blinking Battery Can Not Be Found - 08-17-2012, 02:01 PM
My dell mini 10v was working fine with OS X. I charged it as I have done so many times. Now when I boot I get an error system canot recognize or find the battery. Without the power adapter plugged in it will not work at all. I take the battery off and then the system boots fine but shuts down sometimes. I have read that I need to flash the bios which is AO6. Any ideas on how to correct this. I can see if the battery was failing but it shows 0% while the adapter is plugged in.
Default 08-17-2012, 03:09 PM
I got that same error on my MacBook when it needed a new battery, so I imagine the same is true for the 10v, good luck!
Cool 08-17-2012, 04:03 PM
is this the original battery or is it a 3rd party battery?, many have had issues with 3rd party batteries behaving the same way, if the BIOS has been ok up til now then its probably still ok, I usually do not recommend messing with the BIOS, any mistakes and you might wind up with an expensive paperweight or doorstop, is there another place you can check the battery (ie. a friends system)?, also just try leaving the battery in overnight charging and see what happens, also did you let the battery get down to 0%, I never let mine drop below 40%, letting it go down to 0% sometimes causes problems too...
PS. Welcome to the forum......
BTW: you joined this forum in June 2010?, and this is your 1st post?????????????????????
if you do need a new battery you can check here:
My Digital Discount at MyDellMini
they happen to be one of our forum sponsors and have good prices and dependable products
Dell Mini 10 (Obsidian Black 1010), 2gb RAM, 1.6ghz 533mhz FSB (Z530) processor, A10 BIOS, 1 Terabyte (1000 GB) WD Scorpio Blue Hard Drive (5400rpm), Intel GMA 500 Integrated Graphics, TV Tuner, Bluetooth 2.1 module with EDR, 1.3mp Camera, 1366x768 HD Screen, Wireless 1510 b/g/n mini card, 6 cell (56WHr) Battery, 4gb SDHC, 64gb Flashdrive, Targus Netbook Chillpad, Targus Sport Case, Windows 7 Ultimate SP1 (600gb)/Windows 8 (400gb) (Dual Boot)
iPad 4 (64gb),Targus Versavu Case
« Getting a Samsung External LED Screen to Work | Help! Kids allowed upgrades to Mini 10V and now it won't run ..... »
