Dan_Shane Dan_Shane is offline
Dan_Shane's Avatar
Default 06-10-2013, 01:29 PM
Originally Posted by Casper View Post
My 10V has Leopard already installed (10.5.8) Do you know if it can be upgraded to 10.6 using the SL upgrade disk?
I believe a full retail DVD is required, not an upgrade disc.
-- Dan Shane --
Dell Latitude 2100 | Ball Field Green | 2 GB RAM | 500GB 7200 RPM HD | Windows 8.1 Enterprise| Mac OS X 10.6.8 (Snow Leopard)
Dell Inspiron Duo | 2 GB RAM | 320GB 7200 RPM HD | Windows 8.1 Enterprise| Mac OS X 10.6.8 (Snow Leopard)
Default 06-11-2013, 11:48 PM
It depends on what kind of upgrade disc it is. Many of them are just regular install discs, and that can be used to install fresh. I don't think you can do an actual upgrade.
Oscar Oscar is offline
Oscar's Avatar
Default 06-18-2013, 07:58 AM
Both 10.6 and 10.6.3 SL disks were labeled as 'upgrade' disks, but contain the full OS.
You can use either one of those to install on the 10v.
cheers.
Please use my Dropbox Invite link: http://db.tt/4z2wwup
  (#14) Old
sivaram sivaram is offline
Default 03-15-2015, 01:29 PM
MyDellMini Forum - View Profile: FaizSaleem118.
Dell Mini 10v-A Not So Pro Guide. I cannot find this guide with the link you provided in My DellMini.com. Can you send the link
Can any one send the link to my email address--sivaram474@yahoo.co.in
Thanks in advance.
Sivaram
  (#15) Old
litestep23 litestep23 is offline
Default 02-22-2017, 11:15 PM
I know I'm years behind here, but any chance of the guide getting re-uploaded? Would love to check out.
  (#16) Old
darknessblade darknessblade is offline
Default 02-26-2017, 01:40 PM
to my regret i can tell you that this is not possible anymore.
since the original topic starter is no longer on this forum,
nor are the files anywhere to be found even in the forum logs. (tried finding other older files with useful tools, they where gone.)
dell mini 910
supertalent dual wide ssd 128GB
2GB ddr2 400mhz ram
Realtek RTL8188SU
(not the 3G version)
hdd cooler as extra cooling
  (#17) Old
minitom minitom is offline
Default 02-28-2017, 12:45 AM
I deleted all of my osx stuff when I swapped to my new desktop. That was one of the the reasons I had asked if anyone was still using OSX on the mini's. I had quit when chrome no longer was updated for osx 10.6. If I locate the files on backup I will update the post and see where I can drop them. In addition, I think I had copied the guide to word.
  (#18) Old
AppleFanBoy71 AppleFanBoy71 is offline
Default 02-28-2017, 04:16 PM
Dell Mini 10V (1011) | Alpine White | N270 | 2GB RAM | 60GB SSD (OCZ) | Mac OS X 10.6.8 | NBI *51 | 3 Cell Battery
10v, dualboot, guide, osx, windows 7
« No Airport Card Installed after updating to 10.6.7 | - »
