electro303 electro303 is offline
Default No Sound 1:5 boots - 08-12-2012, 10:18 AM
So I have everything working almost on my Dell 10v 10.6.7 but the sound does not work about 1 in every 5 boots forcing me to reboot till it works.
Driver pack was from NetbookInstaller 20100616212351.
Is there an audio patch if this is a known issue ?
jmacie jmacie is offline
Default 08-13-2012, 04:10 PM
I get you don't want to use the search button, as you'll be subjected to reading impertinent subject matter, but the answers are here. You'll have to move either hdaenabler or legacyapplehda kext from extra kext folder and re-install to system/library/extension folder, rebuild mkext and check permissions, usually with kext utility. You have to experiment. It has something to do with a kext bottleneck when loading. P.S. there are many many valuable threads on audio and mirroring monitors here, the answers are here, truly, just search and read, and experiment.
« OSX Recovery USB Boot Method ? | What model is my Dell? Please help! »
