Default Dell Mini 10v running snow leopard wifi problem please help - 01-07-2012, 08:25 PM
I successfully hackintoshed my dell mini 10v with snow leopard however my wifi does not come and and no other connection comes up. it doesnt detect my connection i dont know what to do please help! im guessing the driver is not installed if yes then how do i install it!
Default 01-07-2012, 11:10 PM
Is it listed in the System Profiler?
Are you sure you have a compatible wi-fi installed? Take the cover off the back and make sure it is a Broadcom card as Intel cards won't work.
If it is a Broadcom card and you just need to install the kexts (OS X version of a driver), run NBI.
Running NBI immediately after you finish installing OS X and before it re-boots should be a part of any tutorial, but it wasn't part of the Gizmodo guide and has been reproduced on numerous other sites.
Functioning Hibernation
Default 01-08-2012, 11:26 AM
yeah thanks it works now i ran netbook installer and it worked!
how do i get app store and facetime etc
« Magic mouse dell mini 10v. 10.6.7 | Rosetta on my hackintosh »
