DaHacker13 DaHacker13 is offline
Default Wifi Problem - 06-28-2011, 09:10 PM
Hello, everbody. I am new to this forum, I read Gizmodo's simplistic guide on how to hackintosh my Dell Mini 10v. I did everything correctly, and the install went smooth. I used NetbookInstaller 0.8.5pre to prepare the USB drive.
While going through the installation process, there was a Wifi button on the menubar, and I could click it and select a network. But once the actual Operatin System was installed, there was no option on the menubar to enable Wifi. I can't even connect wirelessly with Network Assistant or Network Diagnostics. Sound works, but I don't need Bluetooth. So what do I do, it is running 10.6.3, I can't update the firmware because I don't have any internet.
What would happen if I ran NetbookInstaller 0.8.5pre, and selected my Partition on my Dell Mini? Would it solve the problem? Please, I need help and that's why I signed up here.
agugnass agugnass is offline
Default 08-07-2011, 09:36 AM
im having the same problem too!
can anyone help?
drew74 drew74 is offline
Default 08-07-2011, 12:23 PM
Try clicking "Go" in the menu bar. "Go to Folder", then enter "/Extra" in the dialogue box that appears. Once you get to it run "". Might do the trick, if not run NBI app again.
wifi problems mini 10v
« WiFi problems with Dell Mini 10v OS X 10.6.2 | Install/ Time Machine restore issue? »
