broboore broboore is offline
Default Problems Restarting on a 10v running 10.6.7 - 05-19-2011, 12:32 AM
I am having an issue that I was hoping someone could help with. I have a Dell Mini 10v that I have successfully upgraded to 10.6.7
Everything works fine except I cannot get the machine to restart from the command bar. When I choose Apple---Restart, the screen goes black but the light stays on and it just sits there. I eventually have to hold down the power button until it turns off and then I turn the power button on again to reboot it.
I cannot figure this out for the life of me. I have scoured the Mydellmini forums.
It is running A05 Bios. I upgraded using Netbookinstaller 0.8.4
0.8.5pre did not work for me
unclemiltie unclemiltie is offline
Send a message via Skype™ to unclemiltie
Default 05-27-2011, 05:39 PM
1: I think you need the updated version of NBI to deal with 10.6.7 (the one with the long string of numbers that I can't seem to remember) That may be part of your issue
2: do you have USB Legacy turned off in the BIOS?
Mini10v: Black, 2GB RAM, 160GHD 10.6.7/Windows 7 Dual-boot, NBI 0.8.4
Mini9: Black, 2GB RAM, 32GSSD, 10.6.7 NBI 0.8.5pre
MacBook Pro:15" Aluminum, 5GB RAM, 640GBHD, 10.6.7
iMac: 20" White 3GB RAM, 750GBHD, 10.6.7
« Is there any way of installing mac osx from internal HDD using an iso file? | Dell mini 10V speedstepping OSX 10.6.7 + NBI ...056 »
