| Guru Posts: 1,375 Join Date: Mar 2009 Location: Texas | The touch pad on the 10v is horrible. I did a transplant with the 1010 touch pad which is better, but still not great. The mini 9 touch pad is awesome by comparison. Did you try and adjust the sensitivity? I set my 2 finger sensitivity 3 clicks from the Low setting and it is OK. As far as NBI, I would avoid the pre, it is pre-release and has some issues. I use this one- http://dl.dropbox.com/u/863180/Netbo...212351.app.zip This version will allow you to update to 10.6.6. My best experience with NBI has been to install it immediately after completing the OS X install, before the machine reboots. It is in the Utility menu and if you are quick and catch it before it reboots you can run it and then everything works as it should. 10V | OS X 10.6.7 | NBI 20100616212351 |BIOS 06|160 GB|1 GIG RAM| 6 Cell Dell Battery Functioning Hibernation Back up Mini 9| OS X 10.6.7| NBI 20100616212351| BIOS 05 | 32 GB SuperTalent | 2 GIGS RAM |
(#4)
| Guru Posts: 1,375 Join Date: Mar 2009 Location: Texas | That version of NBI was released when 10.6.4 came out, it's the last release before the 8.5pre. The boot lag is from the audio kext, more specifically it has to do with when and how it is loaded. The 1010 track pad upgrade. I found the original thread here- Guide: Mini 10 Touchpad into Mini 10v Check out posts 7 and 8 in particular. It is a pretty good improvement over the 10v track pad, but not nice as I want it to be. I really can't quantify why the mini 9 track pad is better other than to say that I have 3 of them and never had a single issue with jitters or jumping. It is very smooth and has actual left and right buttons. 10V | OS X 10.6.7 | NBI 20100616212351 |BIOS 06|160 GB|1 GIG RAM| 6 Cell Dell Battery Functioning Hibernation Back up Mini 9| OS X 10.6.7| NBI 20100616212351| BIOS 05 | 32 GB SuperTalent | 2 GIGS RAM |
(#5)
(#6)
(#7)
(#8)
(#9)
(#10)
| Junior Member Posts: 8 Join Date: Feb 2011 | Ok, thanks a lot to everyone, I'll be back to this thread with a new touchpad and report my progress! One more question: what about 10.5.8? Is everything working as well? I've heard it greatly speeds up booting time and performance, is that for real? |
| Tags |
| 10.6.3, 10v, issues after running nbi, touchpad |
