pavel pavel is offline
Default Fix that super-bright power LED - 09-24-2010, 10:27 AM
The power/charge/sleep light on the Mini10v is SUPER bright, to the point where it can light up a dark room!
Here's a simple mod I did when messing with the trackpad:
I used a bit of purple nail lacquer to paint the plastic diffuser. The light has now been reduced to a nice purplish glow that's about as bright as the screen.
For a dimmer light without the tint, use black nail lacquer diluted with isopropyl alcohol. I do not recommend using acetone as I have found that the amount needed for thinning cause it to dissolve plastic.
Default 09-24-2010, 09:12 PM
Duct tape, it's color matched to the palm rest.
Just yankin' your chain, my led doesn't work at all.
Functioning Hibernation
Kilrane Kilrane is offline
Kilrane's Avatar
Default 09-25-2010, 05:46 AM
Heh, I might have to try that sometime. The LED light Dell used is a bit annoying in low light situations.
Dell Mini 10v | BIOS A06 | OS X 10.6.6 | Atom N270 | 1GB RAM | 160GB HDD | 6-cell battery
« Won't Startup after Update | New mini 10v OS X 10.6 install - noticable audio tick / pop every 5 secs »
