djrichwz djrichwz is offline
Default Problem with my OSX snow leopard when updating to 10.6.4 - 09-17-2010, 03:52 PM
I installed my dell mini 10v using the Retail osx disc and the netbootmaker and got it running perfectly on 10.6.3 but I wanted to update it to 10.6.4 I updated it using the apple update sotware as I thought I had installed it with a retail disc therefore it should work. But when I start from the hardrive I get a kernal panic unsupported cpu. However if I boot up using my usb device (used to install osx) and then load my mac partition it loads and shows as 10.6.4.
why is this and how do I make it so I can just boot from my hardrive with 10.6.4
Hope someone can help
Kilrane Kilrane is offline
Kilrane's Avatar
Default 09-17-2010, 08:53 PM
The first post talks about the fix for kernal panic when you upgrade to 10.6.4
**OFFICIAL** Mac OS X 10.6.4 Update Thread
Dell Mini 10v | BIOS A06 | OS X 10.6.6 | Atom N270 | 1GB RAM | 160GB HDD | 6-cell battery
« iOS Like Keyboard? | Sleep stopped working »
