froberts froberts is offline
Default Need HELP Using NetbookInstaller 1 - 06-20-2010, 04:57 PM
I tried twice to follow MechDrew's step-by-step instructions that everyone says works perfectly but I continue to have problems starting at step 15 (For USB Partition, select OSXDVD). The only option I have on the USB Partition list is "Mac OS X Install DVD", not "OSXDVD" like it says on the directions. I've tried this twice so I know I'm following the directions perfectly. Any ideas why this might be happening?
I tried to continue on anyway and when I put the USB key in the Mini 10v and started it up, I pressed the F12 key and I did get a grey screen, but it did not have my USB drive name, icon, and a progress bar. It just had the normal list of options on the Boot Menu.
I could really use some help. Anyone?
« Software Updates after combo update? | Updating Mini 1011 OS X 10.6 »
