jamesbarnhill jamesbarnhill is offline
Default 05-17-2010, 09:05 PM
Originally Posted by Buggedsee View Post
Thanks again for your help. I changed the keyboard layout to the British layout (found a thread on here @ Mini 9) and all is well. Only thing I need to figure out is the "Option" key...
Liyang on the intartubes - Link to external website for reference
If you can't figure it out, I've made a list:
= Command = Alt key.
= Option = Windows key.
= Control = Ctrl key.
= Shift key.
There you go.
[  MacBook Pro 13" 2010 | 2.4GHz | 4GB RAM DDR3 | 250GB HDD | NVidia 320M 256MB SDRAM 
Dell Mini 9 <I don't own this anymore> | BIOS: A06 | SL 10.6.3 retail DVD | 1GB RAM | NBI 0.8.4RC1 | BT: √ (Tetany's BT Terminal Mod) |
Audio: √ (Akki's Mini 9 Sound and Mic Fix bundle) | Legacy USB: Off | Sleep: √ | Method: My compiled method | Easier method ]
10.6.3 retail, sl 10.6.3 install issue
« Kernel panic on installation (10.5.1 retail disk) | What are the benefits of going from 10.6.2 to 10.6.3 »
