ludasco ludasco is offline
Default Ugh, battery issues on Hackingtosh with many variables. - 05-03-2010, 10:52 PM
Ok, so I know the best way to resolve computer issues is the eliminate potential problems one at a time.
I am hoping if I describe here what happened, someone can help me not have to do that.
So the computer was plugged in to the OEM charger and my dog chewed through it.
I replaced the charger with the targus netbook charger from best buy (buddy works there so I paid 50 bucks instead of 100)
now, when the battery is in, OSX says its charged but the batter light by the track pad blinks white and orange. I know orange only means the battery charge is low.
when I click the battery icon in OSX, it says charged but in bold "Service Battery"
So if I unplug the charger, the computer just shuts off. Essentially the battery is holding no charge at all.
So did the battery get fried when the dog chewed through the cable? Is the new Targus charger the issue?
Please any insight will help.
Default 05-03-2010, 11:13 PM
did you check the wattage of the new charger before plugging it in? does it compare with the original charger?
lauriem04 lauriem04 is offline
lauriem04's Avatar
Default 05-03-2010, 11:54 PM
You'd really be better off with this charger (original Dell, but way cheaper through Wal-Mart): Dell 30-Watt Mini AC Power Adapter: Computers
Of course, that's assuming that your battery, etc. isn't fried. If you need to replace the battery, you can get the 6 cell relatively cheaply from Wal-Mart too: Dell 56 WHr 6-Cell Lithium-Ion Battery for Mini 10 Laptops: Computers
Edited to add: One thing I forgot to mention with the battery is that you may have to shave a bit off the sides since this battery is really designed for the Mini 10 (1010), not the Mini 10v (1011). If you do a search you should come up with a couple of threads that show you how to do it.
Also, you may want to take a look through this thread since the OP had a similar problem (though I can't remember if they were using OSX):
Default 05-04-2010, 04:46 AM
so weird. if i pull out the battery and turn it on with just the targus charger plugged in, works fine. If I start it up with the battery and then plug the charger in, for a minute it says its running off charger adapter, then it changes to say battery power. although the battery lasts a long time, as if its charging slightly slower than discharging. so far, i dont know how to recharge the battery.
Wolf359 Wolf359 is offline
Default 05-05-2010, 05:09 AM
get coconut battery (it's an app) and see if your max charge is really shouldn't be less than 80-90% of your total capacity...
severe severe is offline
Default 05-05-2010, 08:03 AM
Wish I could help ya, ludasco. Though I just wanted to add that I find it funny that Walmart carries the OEM, and you found an adapter at Worst Buy for nearly double with the bro deal. Incredible.
Of course this shouldn't be surprising, I just find it hard to believe people still shop there. Return that thing, will ya?
Mini 10v - SL 10.6.3 - 2GB RAM - A05 BIOS
« Can I use SuperDuper backup to a new 10V? | OS x 10.6.2 Update - Volume does not meet requirements »
