ohmyyikes ohmyyikes is offline
Default My 10v freezes and no audio? Help please. - 04-15-2010, 12:57 AM
My 10v installed 10.6 snow leopard, but audio doesn't work and when I close the lid on my netbook and open it back up the computer freezes....can someone help me with this? One of my buddies helped me install it so can someone explain to me what I need to install?
boman boman is offline
Default 04-15-2010, 05:55 PM
Are you sure it is freezing, or could it be in a deep sleep.
This might fix your hibernation/sleep issue.
1. Open Terminal
2. "sudo pmset lidwake 0" + enter
3. "sudo pmset hibernatemode 3" + enter
4. "Legacy USB-Support" switch off in BIOS.
Now the Dell wake up from hibernation with the power button.
Works fine for me.
Is you install 10.6.0, or did you update it?
What version of NBI are you using?
« It works, Now What? | Upgrade to 10.6.3 - "An error occurred during installation" »
