Unhappy Trackpad settings will not stick! - 03-11-2010, 03:50 PM
Am I the only one this is happening to? My 10.6.2 install went without any problems. But every time I restart I have to go back to the trackpad prefs and
change something to reactivate the settings.
What can I do???
Dell Mini 10v
OS 10.6.2
NBI .083
Default 03-11-2010, 07:52 PM
I agree, they do not stay set. especially noticeable if you are left-handed
Default 03-12-2010, 02:17 AM
FWIW, mine stay set.
Side.Step.Society's Avatar
Send a message via MSN to Side.Step.Society
Default 03-12-2010, 02:45 AM
Try going to "/Users/Your name/Library/Preferences" and deleting the preference file called, "com.meklort.ps2.preferences.plist"
Default 03-12-2010, 02:49 AM
thanks, I'll give that a try next time I am using my Dell Mini...
Default 06-14-2010, 06:17 AM
Did you ever get your trackpad touchpad settings to stop reseting? I am running two users. Setting stay put on the first user (admin) but not the second user. As long as i go to system pref each boot and turn them off and back on, they work fine.
Let me know if you found a silver bullet!
« Problem With Keyboard After Hackintosh | wifi & bluetooth are OFF( »
