(#11)
(#12)
(#13)
| Expert Member Posts: 559 Join Date: Dec 2009 | Do or did you use Windows at some point? If so, did you ever use the Dell wireless utility to disable bluetooth (press F2)? If so that is the problem. It is effectively a pseudo-hardware switch that is effective across OSes (I believe it probably flips a bit in a hidden area of the BIOS). The only way to re-enable BT is to either use the utility in Windows again or *possibly* to reset the BIOS to default settings (I have seen some reports that this works). Even if you haven't used the Dell utility, you might try the BIOS reset... |
(#14)
| Junior Member Posts: 15 Join Date: Mar 2010 | I didn't do that, when I received my mini 10v from seller, directly installing OS X and format all the whole harddrive . I only use one OS (Snow Leopard).---------- Post added at 02:40 AM ---------- Previous post was at 02:32 AM ---------- Quote:
(#15)
| Junior Member Posts: 8 Join Date: Feb 2010 | Fixed finally..got the new module in today..reset bios and it worked..Thanks!! |
« 10.6.2 Performance improvements/Full backup/etc
Installing Ubuntu, Currently OSX on entire drive »
