| Junior Member Posts: 7 Join Date: Jan 2010 | I have searched around here for a solution but I have not found one that helps me. So I decided to write a post. I installed Mac OS X on my Dell mini 10v using the guide at OS X | mechdrew All is running fine except the sound. I had a look in the system preferences and there is no sound device even showing. The sound was working fine when I was using Ubuntu so I know the device exists. Any suggestions?? |
(#4)
(#5)
| Junior Member Posts: 7 Join Date: Jan 2010 | That's another problem I'm having. I can't even restart. I still need to use the netbookCD to get it to book into Mac OS |
(#6)
(#7)
(#8)
| Expert Member Posts: 559 Join Date: Dec 2009 | Quote:
(#9)
| Junior Member Posts: 8 Join Date: Jan 2010 | trying it now. hopefully it doesn't do any harm to what I already have... ---------- Post added at 03:13 AM ---------- Previous post was at 02:48 AM ---------- Well. The install is complete and appears to work well. Thanks!!! Now what's the latest version that works with a 10v? I think I read 10.6.2 somewhere. |
(#10)
BTW, other than some fixable problems with multi-boot setups involving Windows, it is generally safe to run NBI even if you have already run it in the past. In fact, when a new version of NBI comes out, it will be to your benefit to do so because it will probably include updated drivers etc. | |
