Montala Montala is offline
Montala's Avatar
Question Does Wireless Broadband work OK with Vodafone UK? - 01-25-2010, 06:10 PM
Hi,
The title say it all really!
Last year I took advantage of Dell's free offer of a Mobile Broadband card and a 60 day trial of Vodafone, which I later 'signed up' for under an 18 month contract.
It all (of course!) works fine under Windows 7, but I would like to be re-assured that it will still 'work' OK once I 'hackintosh' my Mini 10v, and am (hopefully) running Snow Leopard 10.6.2.
This probably only really applies to UK customers, so hopefully someone 'over here' will have tried it!
markb markb is offline
Default 01-29-2010, 01:10 PM
Latest software for the Apple Mac
download the drrive from vodafone? I'm about to install osx on my mini 9, and will be using this.
Montala's Avatar
Default 01-29-2010, 01:51 PM
Thanks for your reply Mark... I will be very interested to hear how you get on.
I haven't quite got to the final stage of 'Hackintoshing' my Mini 10v yet, as I would like to ensure that the majority of my 'hardware' is fully compatible first.
It is also my intention to 'flash' my Dell 1510 Wi-Fi card to an 'Airport Extreme' as outlined here, but that is still on my 'to-do' list also!
Default 01-30-2010, 09:54 AM
next weekend is X-hour. I'll let you know how it goes.
Default 02-01-2010, 07:54 PM
I got itchy fingers & installed OSX via 'method 3'. I installed the Vodafone package & re-booted. Waited & waited (so s-l-o-w compared to win 7). It cant find the card so no luck. Not helped that regular wifi is dead as well!
EDIT - Plugged into my router with a cable (how quaint) & downloaded the 1/2 GB upgrade for 10.6 & re-created the bootloader, still no joy. Vodafone s/w can't see the card, and airport is still shagged. Network Setup Assistant is an oxymoronic name.
Montala's Avatar
Default 02-01-2010, 11:52 PM
Hi Mark,
Sorry to hear it didn't work!
Which Vodafone package was it you actually installed?... I hadn't realised that they did a Mac one also.
It would be good if you could get the 'normal' Wi-Fi working though... I have a Dell 1510 card in mine, and my thoughts were to 'rebrand' it as an 'Airport Extreme' card following the guide here... which is also discussed in this thread!
Aren't computers fun!
Default 02-02-2010, 08:22 AM
I've got it working, using the modem script from here and the OSX Network Preference tool. it's all a bit clunky, but as I cant get airport to work (I suspect it's because I had wifi & bluetooth turned off under windows before installing OSX), it'll have to do.
Montala's Avatar
Default 02-02-2010, 08:47 AM
Well done... I am probably being a bit 'thick', but which modem script are you actually refering to here?
Do you mean the one you mentioned in your earlier post #2?
Thanks.
Default 02-02-2010, 11:45 AM
the script etc. is explained here: HOWTO: Using mobile broadband / WWAN module in OSX
Montala's Avatar
Default 02-02-2010, 12:07 PM
Thanks again... I didn't even think of looking in the 'Guides' section... doh!
« Where does "NetbookBootMaker" come into the install? | Can finish my os 10.5 install »
