Default Installation problems on both Method 1 & 2: need advice - 01-10-2010, 08:10 PM
Tried two different methods, and have different issues with each
Computer : New 10v with A06 firmware
USB: 1 gb & 16 gb, both reformated per method used
Software: retail version of Snow Leopard 10.6
Both mechdrew methods
Method 1 Netbookmaker USB on Mac
Error: kernal panic(cpu 0 caller 0x1b33f459 "Unsupported CPU: family=0x6
Tried redoing the complete process twice with no luck
Method 2 NetbookInstaller Two USB on Windows
1st try: appeared like it was working, got thru initial Mac DVD selection process before crash
Succeeding trys: get error 'Can't find mach_kernel' quickly before even starts loading.
Also attempted to redo complete process including reformatting USBs with no luck
What should I try next ?
Thanks
10v, 10v sl issues, mechdrew, nbi
« Will this configuration of a 10v be hackintosh compatible? | Failed to install neccassary support files »
