rr409 rr409 is offline
Default NBI 2 - Mechdrew guide problem - 12-30-2009, 03:51 PM
ok everything boots however if i have both plugged in USBs then it hangs on dell logo blue bar just stops i have bios A04 and if i just leave the bootloader in then get past bluebar and plug 2nd usb in i hit the drive that is suppose to install mac os x in the bootloader and i just get simple message saying no loader
05GT 05GT is offline
Send a message via Yahoo to 05GT
Default 12-30-2009, 03:53 PM
Have you tried booting with both USBs plugged in?
Default 12-30-2009, 04:17 PM
yes it hangs on blue dell bar
Default 12-30-2009, 09:44 PM
Check to make sure you have the proper BIOS settings as specified in the guide, or try different thumb drives. Sounds like maybe it's hanging on registering what's plugged into it.
« Keyboard mapping, Sweden. | Recommend a monitor that works with my 10v »
