jube jube is offline
Default Problem with External Monitor with 10v on OS X 10.6.2 - 12-18-2009, 06:30 AM
When I plug in my 10v to an external monitor the entire computer completely freezes up (and I have to hard shut down). Disconnecting the monitor does not unfreeze it. I've tried putting the computer to sleep, then plugging in the monitor, and then resuming from sleep, but that also freezes it. I've also tried restarting with the external monitor hooked up, but then I get stuck at a blank gray screen during startup.
I'm running a 10v with 10.6.2 NBI 0.8.3 RC4
Sorry if this question has been asked before, I found one post with a similar problem but no solution.
unclemiltie unclemiltie is offline
Send a message via Skype™ to unclemiltie
Default 12-19-2009, 05:07 AM
put it to sleep, wake up and then try again.
for some reason, the external screen hangs the machine when you put the external monitor on for the first time after a cold start.
« tips and lessons install snow leopard on mini 10v | Restart error »
