Default Sound after sleep woes - 09-27-2009, 02:30 AM
Mini 10v running 10.5.7 w/BIOS AO5 with Dell EFI for 10v. Everything works well except for no sound from internal speakers after sleep. I read through all the threads and installed Verbhelper.kext using the Kext helper app. It said it was installed properly so I then repaired permissions and rebooted. Still no internal audio after sleep. I thought that Verbhelper.kext was supposed to be the fix for this and nothing else was needed.
So now what? Do I go through the sleepwatcher fix? I would rather not but if it's the only way I will try it. If so do I have to uninstall the Verbhelper.kext and if so how do I do it? Can I just delete the kext file and that's it? I'll be very happy to get this working as this will give me a perfect install. Thanks for any help and input on this. Appreciate everything this forum has done.
Black Mini 10v | Mac OS X 10.6.2 | 2 GB RAM | 250GB HD | NBI 0.8.3 R5 | 6 Cell Battery | BIOS A06 | USB Legacy Mode: OFF | Bluetooth: None
Default 09-27-2009, 07:27 PM
Here's the answer for anyone else with this problem. This was from Shine On, who provided this very simple solution for me:
I just put Verbhelper.kext in /Extra and ran update extra. Kext helper inst necessary for any kext additions done on the minis and there's less risk of complications using the /Extra directory.
I did uninstall sleepwatcher after I installed Verbhelper.kext, but I ended up reinstalling because sound would work about 90% of the time after sleep, but still would, on occasion, disappear after sleep.
« Mini 9 to Mini 10v Migration: My Fix for Sleep Problem | How do I make my keyboard like a desktop keyboard? »
