nervis67's Avatar
Default noob needs help with sleep issue on mini10v OS X 10.5.8 - 09-05-2009, 08:30 PM
can anyone steer me in the right direction to fixing the sleep issue. I have been trying to find the right thread but i havent had any luck.. I used the NetBookMaker 0.8.2 RC4 method to install OS X on my mini10v. I also did the combo update to 10.5.8 Any help would be greatly appretiated.
Mini 10v | 1Gb RAM | 160 Gb HDD | OSX 10.6.6 | NetbookInstaller .8.4RC1 | BIOS A04 | USB Wake : OFF | USB Legacy : ON | No BlueTooth
TheAAPLFreak's Avatar
Default 09-06-2009, 03:39 PM
Okay, you need to do the following:
Download the DellEFI for 10v (search that in the search box). Place it onto your netbook and run the "Generate system specific dsdt.aml". This will overcome most sleep-related issues. Also, turn off USB legacy support in the BIOS, and voila! You should have 100% working sleep.
nervis67's Avatar
Default 09-10-2009, 02:14 AM
Thanks for the help.. i will try that right now
Toonvox's Avatar
Send a message via Skype™ to Toonvox
Default 09-13-2009, 02:52 PM
Well? How'd it work out?
« Dell 10v sleep in osx | Dell Mini OSX questions »
