Dell Mini 1018 Forum for discussion on the refreshed Dell Mini 1018, released Q3 2010.
Kamen Kamen is offline
Default 12-25-2010, 09:07 AM
Originally Posted by holmes4 View Post
When you run the switcher, does it also list Bluetooth as an option? You may need to revisit the BIOS and look for Bluetooth in the various screens.
It enabled from the BIOS, but look what i have from the swicther.
sp1d3rmunky sp1d3rmunky is offline
Default 04-29-2011, 10:52 PM
Not sure if you found a fix yet .... But I've had the same problem in windows 7 ... I fixed it this way
When the generic driver was installed
Go to device manager > Right click on Bluetooth Device > On the power tab uncheck switch off device to save power
After that I was able to reinstall the software from dell without the No device detected error and all is well, I can use my Bluetooth again
« Issue when installing 2GB ram | Unknown Device in Windows 7 pro install? »
