Unhappy Lights out for my 1012 - advice? - 11-27-2011, 05:06 PM
Hi DellForums! My crash seems identical to another user's post.
When I power it up, the power light stays on, the hard drive light comes on briefly but never lights up again. The screen does not come on at all. I suspect it overheated and disabled a component of the motherboard.
Should I try to have the motherboard replaced on current 1012? Or just buy a new 1012 and swap in my current hard drive?
Any advice or viewpoint is appreciated!
Kiki's Avatar
Default 11-27-2011, 08:33 PM
Try to unmount the HDD than boot up the machine again.
Dell Mini 1012 Black ; Windows 7 Ultimate64 ; Intel Atom N450 ; HD TrueLife 1366 x 768 Screen ; 2GB RAM ; 120GB OCZ Agility3 SSD ; 6 Cell Battery ; Broadcom Crystal HD Media Accelerator ; Dell 365 Bluetooth ; Dell 1510 WLAN ; Dell 5540 HSPA Adapter & GPS ; 1.3MP Camera
Default 11-28-2011, 06:11 PM
I unmounted hdd and had same result.
I've read that some laptops can be stuck in hibernation mode. Any ideas are appreciated!
Default 01-02-2012, 06:58 PM
Fixed! I discovered the problem was simply that the 2 GB RAM memory stick failed. Another Mini 1012 has the same problem when I swapped in the deficient RAM stick. I replaced it, and it started up again fine.
Default 01-03-2012, 07:30 PM
Thanks for not being one of those "NVM GUYS I FIXED IT and I'm not leaving any explanation on how I resolved it!"
DELL MINI 1012 - PNY 2GB PC6400-800MHZ RAM - SAMSUNG 160GB HDD - INTEL ATOM N450 - WINXP SP3
« 1012 memory upgrade | Screen Saver problem on Mini1012 »
