dragon1015 dragon1015 is offline
Default help - 04-01-2011, 11:38 AM
I am a first time ownwer of a 1012, it looks good but am having trouble with wireless network connections, it can see the network but will not connect. Can anyone help! Am I the only one with this problem out here? Come on
avigar avigar is offline
Default 04-03-2011, 02:43 AM
Is your wireless network secure? Are you using the correct password? Have you tried turning off the security to see if it will connect?
Cool 04-03-2011, 02:20 PM
1. have to tried to ping the router? do you get a response?
2. do a ipconfig /all on the Mini
3. Are you using static IP addressing? or just letting the router assign the next available one?
4. are the DNS addresses correct? very important....(only if you are using Static IP addressing)
5. is the IP address set on the Mini enabled on the router? in other words if the Mini is say '' is '' enabled on the router? (only if you are using Static IP addressing)
6. Dumb question but wireless is enabled on the Mini right?
BTW: have you tried a wired connection (Mini ====> Router) 1st and does that work?
PS. Welcome to the forum....
malerocks malerocks is offline
Default 04-05-2011, 05:43 AM
1st of all, which connection utility (software) are you using to connect to the network? If you tell us that, we might be able to guide you to connect via it.
« Tips for replacement HDD? | any great news for 1012? »
