Speedracer Speedracer is offline
Default unable to find a compatible srs audio device - 12-02-2010, 06:31 PM
When I boot up my dell mini 1012 I keep getting the following message "unable to find a compatible srs audio device" . Does anyone know how to fix this issue? Thank you.
---------- Post added at 01:31 PM ---------- Previous post was at 12:20 PM ----------
Found a fix at
Default 12-02-2010, 07:34 PM
what happens when you go in to device manager?
TheNyckWest TheNyckWest is offline
Default 12-07-2010, 07:50 PM
I had that initially when I installed some dell drivers from their site which were the wrong ones. you probably have realtek like I have. Go to control panel programs and uninstall the srs audio manager and it should take care of that issue
« Slow to join wifi - will upgr HB95 to 1520 help? | Broken battery latch, help!? »
