DELLsFan DELLsFan is offline
DELLsFan's Avatar
Default 1012 WLAN issue - 06-24-2010, 12:21 AM
Hey folks -
Playing with a 1012 Mini, added some RAM, and installed Win 7 on it. All seems ok post my clean install - except, for some reason - now in Win 7, I can't seem to turn on or off the WLAN using the F2 key ... though Device Manager says the 1397 WLAN card was installed. Realtek LAN RJ-45 wired port works fine.
I also noticed that I can't even enter setup by pressing F2 on post. The F2 keys doesn't seem to work at all. What are some things to check?
Thanks in advance!
« Display color flickering issue | lagging »
