rhenzhen rhenzhen is offline
Default Help! Problem after upgrading the memory Mini1012 - 02-26-2010, 02:16 AM
Can someone please help me! I upgraded the memory of my Mini1012 from 1gb to 2gb of ram. After i successfully replaced the memory and tried to turn it on. It won't boot up. I hear 4 beeps and it keeps repeating. Does anybody here what it means? I also put it back the original 1gb of ram and the beeps didn't go away. Please help!
Kingston 2GB 200-Pin DDR2 SO-DIMM DDR2 800 (PC2 6400) Laptop Memory Model KVR800D2S5/2G - Retail - Kingston 2GB 200-Pin DDR2 SO-DIMM DDR2 800 (PC2 6400) Laptop Memory Model KVR800D2S5/2G - Laptop Memory
brookheather brookheather is offline
Default 02-28-2010, 08:47 PM
The memory may not be inserted correctly. Take it out and then put it back at an angle and push in firmly until most of the copper edge disappears into the socket and then push it down so it clips into place.
Dell Latitude E6220 | E6230
edokassiah edokassiah is offline
Default 05-27-2010, 10:12 PM
yup its inserted wrong the beeps are pretty universal it a error code to let you know the ram isnt in there right try to put them on again trust if u were able to take this sucker apart you can re seat the ram right
« WiMax+WiFi | my dell mini 1012 not running HT »
