So I have been reading the posts and attempted to check pretty thoroughly to make sure someone hasn't covered my issue. I plug my Mini 1010 into the wall charger and it blinks amber and white. So of course it's not charging. Now I figured the battery was bad and bought a new one. Still no dice. Then I read about the BIOS upgrade and attempted to do it except that it requires you to have your computer plugged in. If the computer is completely shut off the battery will charge. But it does not turn on with the battery out and the charger put in. So is it hardware with the OE charger. Or a software problem
Oh yeah BTW.. I looked for the airplane mode and was unable to locate it.
