dioni207 dioni207 is offline
Default HELP, MINI1010 not detecting Hard Drive - 10-20-2010, 11:45 PM
Hi friends, can anyone help me the Dell mini 1010 is not detecting hard drive in BIOS, i put another sata hard drive and it s not detecting it neither it was working fine, but then it stop working. Any advice, ill try to update the bios to 04 actually it have 03, with the one i found here with the dos utility.
please help me
Default 10-21-2010, 02:02 AM
the Dell Mini 1010 should be on A10 with an upgrade available to A11 (which is only needed for WWLAN) mine is on A10 (it shipped that way in August of '09), are you sure you have a 1010 not a 1011 (10v)?
dresden dresden is offline
Default 02-25-2011, 09:43 PM
Did you ever get this problem fixed? Did updating the bios fixed your problem. I am currently having the same issue. Hard drive not detected. swapped out the drive and same thing.
« Download Mini 1010 XP restore CDs? | Dell mini 1010 VS Ubuntu (any new guides 2011) »
