hlesley hlesley is offline
Default Battery - 05-01-2010, 03:06 PM
Does the 1010 and the 1011 use the same battery?
Cool 05-01-2010, 04:04 PM
Not exactly, they are very similar though, but one requires shaving off a little bit of plastic around the can do a search on the forum to get more info..
PS. Welcome to the forum...
As 6-cell battery is designed for the mini 10 when used on the mini 10v you need to carve out the cavities at both ends of the battery a little bit so the locking pins can slide all the way.
EDIT: I found the link for you:
Go to that thread and look at post #10....there are pictures showing what needs to be done.....Thanks to Holger
« Need help with run comands? | USB not working? »
