cfarrell cfarrell is offline
Default Audio Volume Levels - 03-11-2010, 09:42 PM
I find the volume levels too low on my Dell Mini 10, even when set to 100%.
I have turned it up full in windows media player, and clicked on the speaker in the task tray, and put that to 100% also.
Is there somewhere else that I need to check/adjust to ensure that I'm getting max volume from my speakers?
I'm using Win 7.
Cool 03-11-2010, 11:46 PM
external speakers are your best bet...the volume levels on these leave a little to be desired, also make sure you have the latest drivers, I found that after I loaded the correct drivers the volume got to be usable...I use the SRS audio drivers..
PS. Welcome to the forum..
Default 03-19-2010, 11:08 PM
Thanks....that's what I was afriad of!
« overheating and clicking :( | help on selection of one »
