Angry Inspiron Mini 10 Will Not Boot. using the FN - 01-05-2010, 11:06 AM
The laptop will not boot atall - there is nothing on the screen but it does give a few beeps when it tries to start. I tried conecting an external monitor but nothing shows on it either. It was working OK running XP. I removed the disk and it works fine connected to another PC. I came across a message using Google that mentioned using the FN key and End to recover from BIOS upgrade problems. Is there a complete list of instructions on how to recover from the problem I have encountered? Thanks in advance for any replies to this message.
Default 01-05-2010, 01:33 PM
How many beeps? This is probably indicating the error code which then should be able to be found on Dells support site.
C:\M11xR2\320GBHD\4GBRAM\W7HP
D:\duo\320GBHD\2GBRAM\W8DP
« GMA 500 Owners Who Want to Use Ubuntu 9.10 Look here.. | Anyone fitted an HD LCD panel into an older M10? »
