Daynja Daynja is offline
Default Hard Drive is Making Noise - 01-02-2010, 06:54 PM
I just got a Mini 10 and sometimes when I start it up, the hard drive makes a lot of noise. It's like a clicking or squeaking sound. Other times it is almost completely silent. If I restart, the sound usually goes away, but if I don't it will keep making the sound when the hard drive is accessed. I made a recording of it here.
I have run all the hard drive tests and it passed them all, but should I still ask for a replacement? Has anyone else had this problem?
Cool 01-02-2010, 08:35 PM
some noise is normal, some drives are just noisier than others I guess.when the machine first boots there are drivers and background processes that are being loaded..but you say if you restart it goes away...I would think that the same processes would be loaded all over again, maybe the drive needs to warm up a little before it stops making noise, if you are uncomfortable with it, I would ask for a replacement while you still can and before you load too much stuff that you might have to wind up reloading again....
PS: Welcome to the forum....and my Mini doesnt make any noise at all, but I did upgrade to a larger drive too, although my original 160gb was quiet also..
Default 01-03-2010, 04:35 AM
That's kind of what I was wondering, but I've had it off most of today and I just turned it on and there was no noise. It's kind of odd that it only happens sometimes. It worries me because any abnormal noise usually means it only has a short time left before it becomes completely useless.
I guess I should have said that this is the samsung 160GB hard drive.
w7ox w7ox is offline
w7ox's Avatar
Default 01-03-2010, 04:48 AM
My 10v is totally silent.
Retired Mini user
WolfKeeper's Avatar
Default 01-03-2010, 06:57 AM
I have two Western Digital drives, the 160GB that came with my 10v, and a 500GB upgrade I purchased later. Both are silent inside the 10v.
Getting an iPad
Default 01-03-2010, 11:21 AM
I have a few thoughts.
It's normal for hard drives to make some noise when accessed. And it's hard to tell from a recording whether the drive is being overly noisy.
You can try to find out what program is accessing the drive, if it's a Windows indexing service or something, that'd explain why the noise is inconsistent.
Also, I expect that netbooks without fans (like the Mini 10), seem to have noisier hard drives, since there's no other noise to compete with drive noise.
Finally, you can try adjusting the drive's AAM setting to reduce the click noise (with a small performance penalty).
Good luck.
Default 01-09-2010, 04:35 AM
I just want to update this thread and say that dell sent me a new hard drive VERY quickly and it is working well. I've restarted it dozens of times and it makes no noise unless I put my ear next to the keyboard. It's western digital instead of a samsung.
Montala Montala is offline
Montala's Avatar
Default 01-09-2010, 03:51 PM
Pleased to hear that you managed to get it sorted OK... and very quickly too, as you say, bearing in mind the time of year etc.
Another satisfied customer for Dell!
chad142 chad142 is offline
chad142's Avatar
Default 01-18-2010, 06:32 AM
as long as the noise isnt the so called "click of death"/ on going clicking you should be fine
Dell mini 10(1010),160GB HD,2GBRAM,Vista 32bit,1.6GHz z530
« Help understanding the video & driver issues | Mini 10 memory runs high »
