Default Mini 10v with battery from Mini 10 - 10-09-2009, 10:41 AM
I've just received a Mini 10v from the outlet but the battery clips won't go in and the battery just falls off when you lift the laptop. The battery is labelled J590M - can someone confirm that this is a Mini 10 battery? I tried a battery from another Mini 10v and it fitted fine so there is some variance in the way the clips work on these batteries.
- Simon.
Dell Inspiron 15R | Dell XPS M1330 | 2 x Dell M101z | 2 x Dell M301z
Default 10-10-2009, 06:25 PM
consider it confirmed. just yanked it out and it says j590m. 11.1v with a 24 watt-hour capacticy right?
sorry but at least you can make them replace it knowing the part number is wrong!
« USB TV Tuner issues in Win7 MCE | New GMA500 + HDMI Audio driver pack for Xp and for 7 from Dell »
