Default Loss of volume control after using Digital TV - 08-04-2009, 05:45 PM
I have just gotten my Mini 1010. I opted for the internal Digital TV option. I have a problem that occurs after using Dell Digital TV and I am wondering if anyone has any idea how to fix.
After starting up my Mini, I can adjust the volume using the icon on the task bar or from the control panel with no issues.
When I use the Digital TV program everything seems to work fine including the volume function within the digital TV program. However once I start the digital TV program I can no longer adjust the volume using either the task bar icon or the control panel. Even after I have exited the Digital TV program I still can not adjust the volume.
The only way that I can recover the task bar icon or the control panel volume control is to reboot the Mini.
I am figuring this is something to do with the Digital TV program because it only occurs after I have opened the Dell Digital TV program.
Has anyone else experience this and if so how did you fix.
Thanks
somms's Avatar
Default 08-04-2009, 06:02 PM
Thanks
http://www.mydellmini.com/forum/dell...html#post86150
You could just try another alternative TV tuner app such as WinTV or GB-PVR...
Default 08-05-2009, 01:32 AM
Thanks for the advice.
I am guessing that all I need to do is to down load the WinTV software. Any ideas where I can find?
« Xubuntu display works! Now: Help me PIMP MY MINI! | HDMI Sound Mini 10 on XP »
