(#41)
(#42)
(#43)
| Senior Member Posts: 112 Join Date: May 2009 Location: Mustang, Oklahoma | Quote:
Fancy effect and no USB / Random Freezes or Stable Video, Not So Choppy video and No Freezes(that ive found yet) and you still get USB. I Just threw all that in there for the Others.. I know you already know meecect. Do You have GMA 500 Graphics? Want to run Ubuntu 9.04 Here is a Link on How-To and get the best FrameRate possible and the correct Resolution. Visit my Blog Via Plasma Burn More Updates coming soon to the blog. | |
(#44)
| Junior Member Posts: 2 Join Date: Jul 2009 | Hi there - Apologies in advance if this is a newbie asking a stupid question. I have a Mini 10 with an HD display running Windows XP, and I've been following this thread for awhile, and finally braved installing Linux (Ubuntu 9.04 via Wubi), because the resolution fix looked straightforward enough (and I hate Windows). I may be totally new to Linux, but I'm usually good enough at following directions. I tried the fix (unsuccessfully) yesterday after unknowingly updating to kernel .14, then ran through the updated version again today. I keep receiving the following error at start-up: "Ubuntu is running in low-graphics mode. The following error was encountered. You may need to upgrade your configuration to solve this. (EE)PSB(O): The stolen base is ox3f800000. (EE)PSB(O): screnIndex is 0; fbPhys is: 0x3f800000; fbsize is: 0x007df000 (EE)PSB(O): First SDVO output reported failure to sync or output is not trainded!!! (EE)[drm] drm Open failed. (EE)PSB(O): [dri] DRScreenInit failed. Disabling DRI. (EE)[drm] Could not uninstall irq handler (EE)PSB(O): This driver currently needs DRM to operate" This is followed by a series of series of troubleshooting/error windows trying to restart the display, including "Xt server already running on specified display. Started on display: 1." Eventually Ubuntu boots with the same stretched 1024x768 I've had since installation. I've been searching all morning for others with this error and the most valid looking fix sounded like using Windows Powerstrip to "copy" the correct resolution to Ubuntu? Any suggestions much appreciated! |
(#45)
| Junior Member Posts: 4 Join Date: Aug 2009 | Thats the error it was giving me last night. If you get to a terminal and do a Code: sudo apt-get install psb-kernel-source psb-kernel-headers |
(#46)
| Senior Member Posts: 112 Join Date: May 2009 Location: Mustang, Oklahoma | Jerick is correct. This should fix your DRM error issue which is noted in the Procedure. Also keep in mind LATE last night I update those procedures so if you used the old steps you might be out of line. But it should be a simple fix. What Jerick mentioned should fix the issue though reguardless. Do You have GMA 500 Graphics? Want to run Ubuntu 9.04 Here is a Link on How-To and get the best FrameRate possible and the correct Resolution. Visit my Blog Via Plasma Burn More Updates coming soon to the blog. |
(#47)
(#48)
| Senior Member Posts: 112 Join Date: May 2009 Location: Mustang, Oklahoma | Hey can someone Explain this for me. Im a bit out of my league here. koldfront.dk Git - psb/summary I Ran across this via another forum. But is it me or is that looking like the Ubuntu-Mobile team is working on some new stuff for the PSB? Can someone that uses git decrypt what im seeing there? Also I Dont know if there is any hope on this. But it seems the folks over at Fedora came up with a good soild solution for the PSB AdamW on Linux and more Blog Archive Intel GMA500 (Poulsbo) on Fedora 11: repository (with working 3D / compiz support) Maybe someone that has the Ubuntu force inside them can take a look at what they did and make it work for Ubuntu? Do You have GMA 500 Graphics? Want to run Ubuntu 9.04 Here is a Link on How-To and get the best FrameRate possible and the correct Resolution. Visit my Blog Via Plasma Burn More Updates coming soon to the blog. |
(#49)
| Senior Member Posts: 112 Join Date: May 2009 Location: Mustang, Oklahoma | Ive been running a new config setup. Thought id share it. Havent had any lock ups yet. AND im getting 130 to 150fps with Compiz Working. Here it goes. Im going off memory on what I did. You must already have done guide written above. I Perfer nano to edit. ctrl+o to save and ctrl+x to exit Open A Terminal: Code: sudo nano /boot/grub/menu.lst Code: kernel /boot/vmlinuz-2.6.28-14-generic root=UUID=c34d1d57-59d3-4f6f-abc1-fd83aea4 ro quiet splash Code: kernel /boot/vmlinuz-2.6.28-14-generic root=UUID=c34d1d57-59d3-4f6f-abc1-fd83aea4 ro quiet nosplash mem=786mb Now for Compiz. Code: sudo nano /usr/bin/compiz Code: WHITELIST=”nvidia intel ati radeon i810 fglrx” Code: WHITELIST=”psb nvidia intel ati radeon i810 fglrx” Code: sudo nano /etc/X11/xorg.conf Code: Option "DRI" "off" and make it look like Option "DRI" "on" Once Rebooted click System -> Preferences -> Appearance and click the Visual Effects tab. I chose “Normal” just to get things started… Now Hope and Pray? LOL Have fun with it .. Also Check out X.Org Wiki - Home check out there FAQ there on some different options you can do inside your xorg.conf file with the 3d/2d settings. Also Play with the Memory settings for the Kernel. I just choice a semi round number. I also installed compizconfig-settings-manager to fine tune the compiz setup you might or might not want to try it? Rotating desktop seems to work. Do You have GMA 500 Graphics? Want to run Ubuntu 9.04 Here is a Link on How-To and get the best FrameRate possible and the correct Resolution. Visit my Blog Via Plasma Burn More Updates coming soon to the blog. |
(#50)
| Junior Member Posts: 1 Join Date: Jul 2009 | sammy I just wanted to say thanks for putting up this tutorial. Also I know there must be a way to compile this install as an iso for quick re-install. Does anybody know how to do that. 9.04 desktop with these settings kills the 8.04 that came with my mini. I tried! the netbook remix and would crash and the performance was horrible. This is wonderful.... Thanks again sammy! |
| Tags |
| display, guide, mini 10, resolution, ubuntu |
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-1010/10461-guide-get-ubuntu-display-work-dell-mini-10-not-10v.html | ||||
| akademic - Intel GMA500 + kernel 2.6.31 ? ubuntu ?? dell mini 1010 | This thread | Refback | 10-03-2009 09:38 PM | |
| Linux Today - An Open Letter to Michael Dell: Why I have no choice but return my Ubuntu Inspiron Mini 10 | This thread | Refback | 08-24-2009 08:33 PM | |
| Ubuntu 9.04 on the Sony Vaio P – with desktop effects! Richard Walker :: Brisbane IT Professional (Infrastructure / Web) | This thread | Refback | 08-20-2009 01:46 PM | |
| Xantiriad's tools Bookmarks on Delicious | This thread | Refback | 08-17-2009 07:16 PM | |
| GeoffLPrice's Bookmarks on Delicious | This thread | Refback | 08-07-2009 09:44 PM | |
| MyDellMini | Site profile | BoardReader | This thread | Refback | 08-07-2009 11:17 AM | |
