  (#121) Old
sammyboy405's Avatar
Send a message via ICQ to sammyboy405 Send a message via AIM to sammyboy405 Send a message via MSN to sammyboy405 Send a message via Yahoo to sammyboy405
Default 12-07-2009, 08:44 PM
Originally Posted by Paulfichtre View Post
but when i use the method above, i can't make 3D works, i did not found out the solution
The Above Solution from what I understand is for 2d Only. I will post later with the new Accepted Method for 9.10 Karmic. But it wont be "Much" different than what this How-to has in it.
Ive been outta the loop for a few weeks doing some other development items and I havent had a chance to get a How-To for 9.10.
but 9.10 3d Does in fact work on the GMA 500.
Dell Mini 10 (1010) - Kubuntu 9.04 / Windows 7 / Ubuntu 9.04 / Fedora 11 / CentOS 5 / More to Try Later
Do You have GMA 500 Graphics? Want to run Ubuntu 9.04 Here is a Link on How-To and get the best FrameRate possible and the correct Resolution.
Visit my Blog Via Plasma Burn More Updates coming soon to the blog.
  (#122) Old
Default 12-07-2009, 08:48 PM
Great !
Thanks a lot !
i look forward to read your post
I've got many friends using the dell mini 10 and want to switch to ubuntu, i'm glad to tell them it's almost ok !
  (#123) Old
Default 12-07-2009, 08:55 PM
Great !
Thanks a lot !
https://wiki.ubuntu.com/HardwareSupp...Poulsbo#karmic
There ya have it. How-to for 9.10
  (#124) Old
Default 12-08-2009, 10:28 AM
This last post should be made into a sticky at the top of the 1010 area..........
  (#125) Old
Jon_J's Avatar
Default 12-08-2009, 01:07 PM
I agree.
With both 9.04 and 9.10 on my mini-10, I've had to look here and on ubuntu dell forums whenever a kernel upgrade comes.
mini 10 - black, 1.6ghz, tv tuner, hd screen, multiboot-> win xp | jolicloud 1.2 | debian 6.03 | xubuntu 10.04 | xubuntu 9.04
zaurus sl-C3100 multiboot-> zubuntu rc1.0 | angstrom opie 2007.12-r18 | cacko 1.23
zaurus sl-C3200 pdaxii13-5.5-alpha4 akita on nand
  (#126) Old
Default 12-12-2009, 01:55 PM
Originally Posted by sammyboy405 View Post
Hi sammyboy, i have installed ubuntu, and followed the link you gave
I typed in a terminal :
wget http://gma500re.altervista.org/scripts/poulsbo_ppa.sh && sh ./poulsbo_ppa.sh
The 2D is ok, but not 3D, what else should i do ?
thanks a lot...
  (#127) Old
Send a message via MSN to KooGa
Default 12-15-2009, 12:25 AM
All I have to say is THANK YOU!
You are the main man.
  (#128) Old
Default Fix Guide under 10.04?? - 09-12-2010, 03:40 PM
SammyBoy - Your step-by-step guide seems to be very detailed, and sounds like allot have had success with it...do you have one for fixing the screen resolutions under 10.04 (lucid)?? I have not had any luck trying to use your guide under 10.04.
Any updates for 10.04 would be greatly appreciated!
Kevin in VA
  (#129) Old
fdalbor's Avatar
Default 09-29-2010, 02:18 AM
Kevin in VA
Go to the ubuntu web site and it has a listing of the ways to get GMA500 drivers that allow better screen resolution. The one for 10.04 is a simple two line command line visit to get the drivers to make 10.04 work correctly.
Even I could do it. Be warned however it distroys video playback with any of the normal video players used with 10.04 on a normal system. So there is a trade off. Still it works like a charm; but without normal video playback.
There is a workaround; but it is not very good. And every time you try to install another video playback program besides the workaround it falters and returns errors. Here's hopping they find a way to overcome this. fdalbor
Compaq R4000 laptop AMD 64
Compaq SR2034NX AMD 64
  (#130) Old
Default 09-29-2010, 04:31 AM
I see that "Xv" video output is listed as broken. But 3D is listed as "Good", so try OpenGL video output. Since "mplayer" makes it easy to change video output methods, I recommend it for testing. "mplayer -vo gl video.avi" will play a video using OpenGL for output.
Also, "mplayer -vo x11 -zoom video.avi" should always work, but it might be ugly and low-performance (I'm guessing this is the workaround you refer to). "-zoom" enables rescaling to fit the screen, which mplayer normally disables when using X11 output for performance reasons. And although X11 output sucks, it should be just as good as video playback with the dumb vesa driver.
display, guide, mini 10, resolution, ubuntu
« Mandriva 2011 on 1010 | Help: fried battery or motherboard »
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-1010/10461-guide-get-ubuntu-display-work-dell-mini-10-not-10v.html
Posted By For Type Date
akademic - Intel GMA500 + kernel 2.6.31 ? ubuntu ?? dell mini 1010 This thread Refback 10-03-2009 09:38 PM
Linux Today - An Open Letter to Michael Dell: Why I have no choice but return my Ubuntu Inspiron Mini 10 This thread Refback 08-24-2009 08:33 PM
Ubuntu 9.04 on the Sony Vaio P – with desktop effects! Richard Walker :: Brisbane IT Professional (Infrastructure / Web) This thread Refback 08-20-2009 01:46 PM
Xantiriad's tools Bookmarks on Delicious This thread Refback 08-17-2009 07:16 PM
GeoffLPrice's Bookmarks on Delicious This thread Refback 08-07-2009 09:44 PM
MyDellMini | Site profile | BoardReader This thread Refback 08-07-2009 11:17 AM
