  (#101) Old
Jon_J's Avatar
Default 10-23-2009, 07:45 PM
Edit: Mosaic, read my next post. I found a solution to the kernel upgrade problem.
After reading mosaic's post above, I decided to run update.
It installed 2.6.28.16 kernel, but near the end of this process there was a popup.
It gave me several choices for my grub menu.lst
I choose "Keep original" (I was hoping not to "break" my psb video)
Upon rebooting, I only have the choice to boot 2.6.28.15 kernel.
I was hoping my menu.lst would have more choices now, including 2.6.28.16 kernel, but it doesn't.
I found a solution, read my next post below.
To Mosiac
Try booting to the "older" kernel at the boot screen.
If your boot screen doesn't include choices for both "new" and "old" kernel,
check your /boot/grub/menu.lst and see if there are entries for the "old" kernel commented out.
mini 10 - black, 1.6ghz, tv tuner, hd screen, multiboot-> win xp | jolicloud 1.2 | debian 6.03 | xubuntu 10.04 | xubuntu 9.04
zaurus sl-C3100 multiboot-> zubuntu rc1.0 | angstrom opie 2007.12-r18 | cacko 1.23
zaurus sl-C3200 pdaxii13-5.5-alpha4 akita on nand
  (#102) Old
Jon_J's Avatar
Default 10-24-2009, 12:03 AM
Mosiac,
I found this post at ubuntu forums about updating the graphics after a kernel upgrade.
[all variants] Guide to Get the Best Performace from the GMA 500 - Page 8 - Ubuntu Forums
Read post# 75 and 76.
I used the solution in #76 as follows:
I didn't try to boot the "new" kernel in normal mode first.
I booted into "Ubuntu 9.04, kernel 2.6.28-16-generic (recovery mode)
Once in Recovery mode, I selected "Drop to root shell prompt"
Then I issued the following in the console:
Code:
sudo dpkg-reconfigure psb-kernel-source
The currently loaded psb stuff unloaded and uninstalled,
then it recompiled and reinstalled the psb kernel stuff for 2.6.28-16
When it was completely finished, (I got my prompt back) I typed "exit"
Back in Recovery mode, I then selected: "Resume normal boot"
It booted to my xubuntu desktop with 1366x768 resolution.
I rebooted again just to make sure it "took"
BTW, I first needed to re-enable my "new" kernel in grub.
I edited menu.lst after researching this.
All I did was "copy/paste" the 2.6.28-15 kernel entries above their original location.
Then I changed all instances of "15" to "16"
Saved and rebooted.
  (#103) Old
mosaic's Avatar
Default 10-24-2009, 01:42 AM
thanks Jon_J...I have been having a dreadful time with my little baby here today...I had already tried to boot into the older kernel, but when I did so I found that i was still getting the error, decided that perhaps the psb got corrupted and figured that I would just re-do the original procedure....at which time I discovered that I no longer had internet access. Sigh....it is always something I guess :-) Of course that is why I loaded my mini with ubuntu...done with windows, time to learn about and explore something new.
I am going to try your instructions, and I will let you know how it goes.
---------- Post added at 08:42 PM ---------- Previous post was at 07:48 PM ----------
OK, now I am really frustrated...
No dice on your solution, Jon_J although it was certainly logical. I got an error that said that module directory does not exist, and that the kernel-source is broken or not completely installed. so I tried removing the package (apt-get remove) and then reinstalling it, but it threw an error each time saying that the directory does not exist and then refused to completely install it.
I am not sure what to try next....please help!
  (#104) Old
Default 10-24-2009, 04:11 AM
im having the same problem as mosaic with the no directory error has anybody figured out a solution yet
  (#105) Old
suspendedrain's Avatar
Default Error! Could not find module source directory. - 10-24-2009, 08:22 AM
Hey Mosaic,
I had the same problem after the 2.6.28-16 update. Every time I tried to update or reinstall psb-kernel-source, I would get the following error:
Directory: /usr/src/psb-kernel-source-4.41.1 does not exist.
dpkg: error processing psb-kernel-source (--configure):
subprocess post-installation script returned error exit status 2
Errors were encountered while processing:
psb-kernel-source
E: Sub-process /usr/bin/dpkg returned an error code (1)
To correct the problem, I had to first purge then reinstall psb-kernel-source.
I'm up and running again after running the following:
Code:
sudo dpkg --remove psb-kernel-source
sudo dpkg --purge psb-kernel-source
sudo apt-get install psb-kernel-source
I hope this helps.
  (#106) Old
Default 10-24-2009, 06:07 PM
suspendedrain thanks that fixed my problem i hope it fixes other peoples problem too
  (#107) Old
mosaic's Avatar
Default 10-24-2009, 06:35 PM
Awesome suspendedrain!!!! Fixed that right up...I am back in the game now. Thanks!
  (#108) Old
Default 10-31-2009, 10:54 PM
I upgraded to the 9.10 distro, and now my display is back to crappy. Apparently the Poulsbo drivers for 9.04 don't work in 9.10. Are there updated drivers? Anyone know how to get the Mini 10 with GMA 500 to work with Ubuntu 9.10?
  (#109) Old
Jon_J's Avatar
Default 10-31-2009, 11:11 PM
sulpicius,
Go to below link, and follow the instructions in the first post to the letter.
At the point in the instructions where you dpkg -i psb-kernel-* you'll get an error.
Don't worry about the error message.
The error is because dpkg tried to install the tar.gz as a deb. Nothing to worry about.
Get GMA500 (Poulsbo) working in Karmic with Jaunty backports.. - Ubuntu Forums
Because of that thread, I have Karmic 9.10 working fine on my Mini-10 at 1366x768.
  (#110) Old
Default 11-08-2009, 12:22 AM
hi
i am following this howto on my dell mini 10, thanks to sammyboy405
but when i enter this command :
sudo apt-get install poulsbo-driver-2d poulsbo-driver-3d psb-firmware
i get this :
Lecture des listes de paquets... Fait (reading packets ok)
Construction de l'arbre des dépendances (building of dependances tree)
Lecture des informations d'état... Fait (reading info ok)
Certains paquets ne peuvent ĂȘtre installĂ©s. Ceci peut signifier
que vous avez demandé l'impossible, ou bien, si vous utilisez
la distribution unstable, que certains paquets n'ont pas encore
été créés ou ne sont pas sortis d'Incoming.
L'information suivante devrait vous aider Ă* rĂ©soudre la situation :
Les paquets suivants contiennent des dépendances non satisfaites :
poulsbo-driver-2d: Dépend: xserver-xorg-video-psb mais ne sera pas installé (won't be installed)
poulsbo-driver-3d: Dépend: xpsb-glx mais ne sera pas installé
E: Paquets défectueux
sorry for my bad english, but could you please help me ? i cannot continue your howto...
thanks in advance
paul
display, guide, mini 10, resolution, ubuntu
« Mandriva 2011 on 1010 | Help: fried battery or motherboard »
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-1010/10461-guide-get-ubuntu-display-work-dell-mini-10-not-10v.html
Posted By For Type Date
akademic - Intel GMA500 + kernel 2.6.31 ? ubuntu ?? dell mini 1010 This thread Refback 10-03-2009 09:38 PM
Linux Today - An Open Letter to Michael Dell: Why I have no choice but return my Ubuntu Inspiron Mini 10 This thread Refback 08-24-2009 08:33 PM
Ubuntu 9.04 on the Sony Vaio P – with desktop effects! Richard Walker :: Brisbane IT Professional (Infrastructure / Web) This thread Refback 08-20-2009 01:46 PM
Xantiriad's tools Bookmarks on Delicious This thread Refback 08-17-2009 07:16 PM
GeoffLPrice's Bookmarks on Delicious This thread Refback 08-07-2009 09:44 PM
MyDellMini | Site profile | BoardReader This thread Refback 08-07-2009 11:17 AM
