Dell Mini 10 Guides Guides, Articles and How-To's for the Dell Mini 10
| | LinkBack | Tutorial Tools | Display Modes |
| Guide: Mini 10 Touchpad into Mini 10v
Published by DeanJ 09-04-2009 | |||||||||
#1
| DeanJ. I moved your thread and made it a guide. ![]() Good work!! If you could edit the original post and include all information in that post then things would be more organized. Right now, your pictures are showing up in the "comments". I can help clean this up for you if you would like.
__________________ Mini 10v | 2Gb RAM | 320 Gb HDD | Ubuntu 10.04 | OSX 10.6.3 | NBI .8.4RC1 | Chameleon Bullet Theme | BIOS A05 | USB Wake : OFF | USB Legacy : ON | No BlueTooth Meklort's Blog | NBI Google Code Page | osx.mechdrew.com -- the best OSX installation guides |
#2
| Will do it now, didn't know if there was a limit of how many pics I could post in one thread. |
#3
| Quote:
![]() Thanks for the guide! I am sure it will be a great help.
#4
| Just a FYI for any US types that would want to try this. If you need to add silicon like the OP you can purchase it at pretty much any big box hardware store (Lowes, Home Depot, etc.) or Walmart. Look for clear bathtub silicon caulk in a 8" plastic tube in the plumbing section (for hw store) or hardware (for gp store). Should cost around 5 bucks. Smaller mom and pop hardware stores would most likely have it also for maybe a buck more.
__________________ Mini1: Vostro A90, Black, 2G, 1.3 Webcam, Bluetooth, 64G SuperTalent, OS X 10.6.4 Mini2: Mini9, Black, 2G, 0.3 Webcam, Bluetooth, 32G RunCore, OS X/Win 7, internal PCI-e SHDC Reader Mini3: Mini10v. Black, 2G, Webcam, 640G HD, OS X 10.5.8/Win 7/Ubuntu [Hibernate w/NBI 0.8.3 RC4] Dropbox Referral |
#5
| What advantages does the Mini 10 trackpad have over the Mini 10v trackpad? i.e. why would you want to do this upgrade? |
#6
| It's pretty much better in every way to the mini10v's trackpad. Since this pad is multitouch it no longer suffers from the jumpiness when using the built in buttons. This allows you to to hold the button, drag your finger across the pad and have it act as expected. This simple behavior is the source of much frustration on the mini10v. Other than that, tap to click is now 100% reliable (which has been an issue with netbook installer's drivers). Two finger scrolling works beautifully, two finger clicking seems to trigger a middle click on a mouse and three finger clicking works as right click. The only down side is that the trackpad is very sensitive at the default settings, but OSx seems to recognize this trackpad as a mouse and not a trackpad and as such you can adjust the speed settings under the 'mouse' tab in system preferences. I highly recommend this upgrade. The silicone used in the original post isn't necessary as there is a little plastic clip which holds the top of the trackpad. I know I had some reservations about using such a hackish method.
__________________ Dell mini 10v OSx 10.6.2 | Windows 7 |
#7
| I have done the upgrade as well but did not require any silicon to hold it in place. If your very careful you can bend the metal on the front of the touch pad up and then back flat so you can use the screws to actually hold it down. When I get home tonight I will take some pictures since I did this in the office this morning when I came in. Took about 15 minutes and that includes tracking down some pliers to do the bending. Touchpad works great have clean 2 finger scrolling and light touch just like my MacBook Pro. Now if I just had 4 finger scrolling I would be in hog heaven. ![]()
__________________ Dell Mini 10v|2GB Ram|Mac OS X 10.6.0|Bios A05|160GB |
#8
| Here are the photos I promised Backside -> ![]() Upclose of tab -> ![]() Front of Keyboard -> ![]()
#9
| anybody finding that the screws holes on the 10v palm do not fit perfectly on teh 10 touchpad? when i screw in the two screws, the front of the palm rest becomes slightly bow. |
| Tutorial Tools | |
LinkBack to this Thread: http://www.mydellmini.com/forum/dell-mini-10-guides/12431-guide-mini-10-touchpad-into-mini-10v.html | ||||
| Issue 25 - netbook-installer - Add support for mini10vs using the mini10's Elantech touchpad - NetbookInstaller is a tool used to install Mac OS X on numerous netbooks - Google Project Hosting | This thread | Refback | 07-08-2011 10:17 AM | |
| Elantech Touchpad « Meklort's Blog | This thread | Refback | 09-25-2010 05:30 AM | |
| Elantech Touchpad Meklort's Blog | This thread | Refback | 12-17-2009 11:31 AM | |
| Guide: Mini 10 Touchpad into Mini 10v | This thread | Refback | 10-01-2009 05:29 PM | |
| quattroworld.com Forums: i guess lots are unhappy Dell changed the touchpad on the 10v | This thread | Refback | 09-13-2009 09:20 PM | |
| Dell Mini 10 Guides | This thread | Refback | 09-11-2009 07:49 PM | |
| Issue 25 - netbook-installer - Add support for mini10vs using the mini10's Elantech touchpad - Project Hosting on Google Code | This thread | Refback | 09-10-2009 02:30 PM | |
