Charlie Charlie is offline
Charlie's Avatar
Default Duo battery replacement - 03-28-2013, 08:34 PM
Can someone tell me where I can find that video on how to replace the battery in the Duo? I'm almost sure I seen one somewhere but I can't seem to find it.
Thanks
---------- Post added at 05:34 PM ---------- Previous post was at 05:03 PM ----------
Never mind, I just started taking screws out and I got it. Pretty easy once you do it, doesn't take long.
Thanks anyway
« Inspiron Duo Screw Size | AHCI vs ATA? »
