Unhappy Problem: Sudden shutdowns - 11-11-2011, 04:49 AM
My dell inspiron duo is suddenly shutting down when unplugged and this only happens when I move the notebook like in 50% of those times. Very weird.
It´s not an overheating issue becuase it happens soon or late after starting it. I think it is a system crash that is motivated by a screen movement sensor or something like that.
I can move it when plugged, but, whats the point?
I know the battery average is bad on the duo but this happens even when charged.
I have downloaded dell fixing programs and even paid for them to fix the computer... I got a little bit faster but the shuttingdown proble persists.
Am I the only one with this weird problem?
Default 11-21-2011, 07:06 PM
Nope. I'm having the same issue. Currently waiting for Dell online support. I'm fed up with it, as it's happenign more and more often.
It also generally won't power back on until I've plugged it into AC power (even though the battery is fully charged)
*EDIT: Dell tells me it's an internal problem. Sending it in to the repair depot :/
Disappointing, to say the least. I guess this means I will lose my Thinix Touch software, too, since I'm out of activations.
Default 11-21-2011, 10:51 PM
I've not had the issue as yet, however, it sounds suspiciously like an issue related to the power management theme for the unit, either sneaking into sleep, hibernation or shutdown.
Thats the first area I'd check and to test would create a test theme of NO blank, sleep etc for battery once to see if she'll drain down once, without crapping out on you.
I'd certainly do that first before waiting on Dell support unless you have an extended everything best service contract.
Just my two cents.
Default 12-07-2011, 12:42 PM
I got my unit back from dell yesterday. According to their paperwork, they replaced the battery and the battery connections (I've not seen inside the unit, so i don't know entirely what that means).
But after speaking to a care representative, there may be an issue with some units in that the battery is improperly installed, and when uit is moved suddenly, it loses the connection between the battery and the unit (it sort of "shifts" inside the case).
I can't speak to the statement's acuracy. Regardless, I tested it extensively last night for quite a bit on battery power and I had no sudden shutdowns. So here's HOPING that did the trick.
EDIT: Day 2 and still no sudden shutdown. So far, so good. Used it extensively last night.
Default 12-13-2011, 09:59 AM
Just my 2 cents, I had this issue for weeks, it was annoying the heck out of me, then I disconnected the battery, and reconnected the battery and haven't had problems since. Not saying this will work for others, but who knows it might.
Default 12-13-2011, 05:17 PM
By the way...I also appear to be getting better battery life since the servicing. i was struggling to get 2 hours of web surfing before, and I got 2 hours 35 minutes last night and still had a little juice left when I shut it down. (It said I had 10 minutes)
I may have had a defective battery or something.
Default 12-16-2011, 04:20 PM
I've not had the problem, but am curious if you found a way to do that yourself -- or did you have to find a tech do that?
dell, duo, problem, shutdown, sudden
« Looking for Duo Stage | Farewell to duo? »
