JaJaWa JaJaWa is offline
Angry Audio Station cutting ou... - 03-07-2011, 10:09 PM
Just wondering if anyone else's Audio Station has an issue where the sound cuts out every minute. I have to take the duo off, wait 15 secs and then put it back on for the audio to last another 30 secs or so. It's an incredibly annoying issue - and strangely even happens with headphones plugged in the ports on the back of the Station.
Also, the volume buttons on the side of it have never done anything (when the duo's docked of course), even when I hadn't uninstalled any programs - don't know if this issue is related.
Weirdly, the sound doesn't start coming out the duo's speakers - it still knows it's docked.
Don't know how long the cutting issue has occured for considering I'd never used the Audio Station before really - didn't see it as much use, but now have plugged a bigger keyboard and a mouse in the back to create a desktop style computer.
cms cms is offline
cms's Avatar
Default 03-09-2011, 01:32 PM
Make sure you installed the right audio station driver from dells support website. The volume buttons on the side should work like the volume buttons do on the DUO. Which seems to me like your lacking the proper driver.
My Dell Duo Tips Blog:
Solder-mod'er from the eeeuser forums.
Inspiron duo - Win7 ult x64 - Linux Simul. OS
EEE 1000he - 2.1ghz OC - 12hr battery
Default 03-09-2011, 05:34 PM
The audio station has used the driver "SRS Premium Sound APO for Conexant for USB Audio" from when I got the duo.
I downloaded this driver again from Dell's duo page and that hasn't seemed to fix it
Default 03-11-2011, 09:49 PM
Re: Inspiron Duo docking station wont play BBC iPlayer or 4oD - Laptop Audio Forum - Laptop - Dell Community
Someone just happened to post this a couple of days ago, but I've found the fix (for any application)
Just load a website with a Flash video, right-click the video, click Settings, then UNCHECK Hardware Acceleration.
Fixes the issue completely, even for Windows Media Player etc...
No idea why tho ;D
Javy23 Javy23 is offline
Default 08-18-2011, 03:09 PM
Hi JaJaWa!
I have the same issue! I just got my audio station and happen the same. When I plug it, stops suddenly.
could you explain me how did you fix it?
Is it a diver issue?did you download something?
Many thanks in advance...I hope hear about you soon!
audio station, cutting out, dell duo, not working, stopping
« Engadget Hands On | Help - mouse is disabled! »
