(#11)
(#12)
| Member Posts: 61 Join Date: Jan 2011 Location: Essex, UK | Ok ive had a bad day. I went ahead and bought the 128GB OCZ Onyx SSD Firstly. I hadn't seen this mentioned anywhere before but the Hdd in the Duo is 2.5" but it is half the height of a standard drive. The SSD would fit in there without the caddy but once the plastic covers are back on it looks like it bulges the laptop out of shape. Has anyone else who has done the upgrade noticed this? Secondly. Once i had fitte4d the drive and got it all back together the BIOS wouldn't pick up the SSD. After a lot of testing and messing around it turns out that the SSD was a dud so I have to RMA it. I am a little reluctant to replace it though if it means bending the laptop out of shape. Also this was the only place around that had the Onyx in stoack. (It has now sold out) and I believe it has been discontinued as it is an older model. Problem being that the main reason i chose this model is because of its very low poer consumption (1W Active 0.375W Idle) and none of the newer ones are that low. Overall a very dissapointing day for me. Hopefully you guys have better experiences than I've had. |
(#13)
(#14)
(#15)
(#16)
(#17)
(#18)
| Junior Member Posts: 13 Join Date: Aug 2010 | Quote:
I talked to a Crucial tech and he said all 2.5 inch drives have a slightly different connector than the 3.5 inch drives so you cannot use a 2.5 inch drive. It appears that Dell got a special configuration manufactured. Anyway, the Crucial 3.5 fits in mine with no bulging. Lou | |
(#19)
(#20)
| Member Posts: 61 Join Date: Jan 2011 Location: Essex, UK | Quote:
lousiefer, 3.5" drives are desktop drives an 2.5" are standard leptop drives. Do you mean 2.5" and 1.8" respectively? I may look at getting a 1.8" drive in there and getting a bit of space to mount an internat flash drive or a GPS unit as i saw on the mini 9. | |
