cjc cjc is offline
Default how to replace wireless card - 01-20-2012, 10:58 AM
how easy is it to replace the wireless card on my dell inspiron 1110 is their any instructions on how to do it thanks
Default 01-20-2012, 12:41 PM
You will need to remove the keyboard and palmrest - instructions for WLAN card here:
Documentation
Dell Inspiron 15R | Dell XPS M1330 | 2 x Dell M101z | 2 x Dell M301z
cjc cjc is offline
Default 01-20-2012, 12:54 PM
many thanks for your help
Default 02-26-2012, 02:54 PM
you should be able to follow the black and the white
arial wires to find it. they come from the screen straight
down the middle to under the mousepad.
see service manual
For more: How to install wireless lan card? | Techyv.com
Default 05-08-2012, 11:24 PM
It is a hard work for me and my new notebook.
« Dell Insprion 11z (1110) Memory Problem | Trying to install xp sp3 on new 11z »
