(#4)
| Senior Member Posts: 106 Join Date: Aug 2009 | Sounds like you may have just had bad luck and got another bad hard drive. I doubt that's a motherboard problem, but you never know. If it is a motherboard problem, it would be a rare problem so you probably wouldn't find much help. You running Linux or Windows? If you're running windows, download HDTune: http://www.hdtune.com/files/hdtune_255.exe And run an Error Scan. It'll check your hard drive for bad sectors. If there are lots of bad sectors, that would be your problem. |
(#5)
| Junior Member Posts: 5 Join Date: Oct 2010 | Quote:
Hi, thanks for answer me. I've tested (on quick mode) and result no errors founded. This sound is very annoying and worrying, gives the feeling of being broken. | |
(#6)
| Senior Member Posts: 106 Join Date: Aug 2009 | What OS are you running? Sounds like it might be a driver problem then. Like I said, very unlikely that it's motherboard but it could be. If you're running Windows, make sure you got the latest drivers here: http://downloadcenter.intel.com/Sear...Chipset+Family |
(#7)
I've windows 7 x64 Ultimate, what drivers I've to get?, I'm just was installed the graphics drivers (from intels web) and chiptsets drivers (from dells support web). | |
(#8)
| Junior Member Posts: 21 Join Date: Apr 2010 | It could certainly be a motherboard problem - if the motherboard has a bad connection or a power rail issue then the HD might be power cycling on and off... It would click and it also would corrupt data. I'd expect it to blue screen with that fault though. Chris... |
(#9)
| Senior Member Posts: 106 Join Date: Aug 2009 | Quote:
I do agree though that most motherboard problems are going to blue screen the computer. That is why I think it is highly unlikely to be a motherboard problem, but you never know without actually being there a diagnosing the problem yourself. | |
(#10)
Thanks both. I don't get any blue screen, just a annoying noise from HD so far; not always, just a random times, mostly on IDLE. But with the Western Digital disk just after about 20 days then begins to gave me a data corruption, this HD was been used about 10 days. So, worring me. | ||
| Tags |
| hard drive, noise, problem |
